Old 05-10-2004, 04:28 PM
dhspring dhspring is offline
2001 Astro van, sticky accelerator
My 2001 Astro van has 43000 miles and a sticky accelerator, once you push on it, it's okay, but from idle position it acts like maybe some carbon build up in the throttle body. Has anyone else had this and what is the solution besides taking it to the dealer and spending $200. Is there a home fix for this, maybe some choke cleaner sprayed in the throttle body for instance. THanks!!
Old 05-21-2004, 04:01 AM
Roaster Roaster is offline
Smile Very simple fix
Use a lithium spray or wd-40 with long tube and spray the lingkage. Mine did the same thing right around 40k and once you mashed the pedel it was ok. This will make it like new again.
Old 05-21-2004, 05:55 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: 2001 Astro van, sticky accelerator
There is a buildup of dirt in your throttle body.
Use a quality choke cleaner and a soft tooth brush and clean the throttle bore and blade
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 05-24-2004, 03:29 AM
bmfzo6 bmfzo6 is offline
a quarter turn of the throttle set screw will do the trick. there is a gm bullein on this.
Old 05-24-2004, 08:01 AM
Re: Very simple fix
Thanks Roaster!
Old 05-24-2004, 08:04 AM
Thanks GMMerlin adn BMFXZ06, I'll try these one at a time till I get her fixed.
Old 06-10-2004, 07:47 PM
3800wattvan 3800wattvan is offline
Uturn1200
I had this problem. Quite aggrivating. Looked down the throttle body and saw nothing. I procrastinated for months and it eventually went away. Not the right way but it worked.
Old 07-03-2004, 08:41 PM
leaddude leaddude is offline
Smile
had same problem on my 2001 astro the cleaning and lube did not do the trick but the 1/4 turn did the job -thanks bmf2o6
Old 08-15-2004, 03:16 PM
skflaash skflaash is offline
sticky throttle
Same sticky throttle on 97 Astro, easily fixed by examining throttle valve plate and spraying THE SNOT OUT OF IT with throttle body cleaner,I wish all my problems were as easily fixed..
Old 11-09-2006, 04:00 PM
2001 ASTRO DUDE 2001 ASTRO DUDE is offline
What does the GM tech bulliten say? Which way do you do a 1/4 turn? I have had the same problem for years. Please help!
Old 11-09-2006, 07:58 PM
old_master's Avatar
Advisor/Moderator
If the problem has been evident since the vehicle was new, most likely a 1/4 turn clockwise on the idle stop screw will fix it. If the problem has gradually gotten worse over time and miles, there's probably a build up of carbon in the throttle body, on the underside the throttle plate where it seats against the bore. Most auto parts stores carry a, (spray can) product specifically designed for cleaning throttle bodies. Follow the directions on the can.
Old 11-10-2006, 08:12 AM
Old Master,
Thank you so much for the reply. I bought this van used @ 58,000 miles and it has always done this. Since I now have over 151,000 miles and it has not gotten worse, I think it's always been this way. I think I will give both tips a shot. A neighbor of ours had the same problem on a 2000 and the repair shop told her that it was bad fuel injectors and charged $90.00 for the fix. This never did make sense to me and now the truth comes out.
