Old 05-10-2004, 05:02 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
AIR/FUEL bad/good gauge
i know everyone always hates on Air/fuel ratio gauges and how they dont work, well i stubleled across this,, http://www.aempower.com/product_ems.asp from AEM and it looks promising with that mini computer thing. i was wondering if any one had it and could tell me if its worth the money?
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 05-10-2004, 05:05 PM
97_3clipse's Avatar
Re: AIR/FUEL bad/good gauge
OMG i just looked its $621
Old 05-10-2004, 05:16 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
From what everyone else is saying they are inaccurate
EDIT>> Nevermind, I see that you knew that , That computer looks like the one from F&F.
For Sale 98 Eclipse GS, 5 spd
Old 05-10-2004, 05:24 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
a/f gauges can be accurate... but i hate to watch that stupid fucking light jump back and forth! i have seen a very few a/f needle gauges and i am sold on them!!! although they are around 350 just for the fuckin gauge they seem to be very accurate! so if i ever have an extra 350 laying around i'll pick one up and let you guys know how it works!!!
Old 05-10-2004, 06:04 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Wideband o2 sensors and a decent gauge or software reads very accurate air/fuel ratio. It's just the shitty 30 dollar gauges on the shitty stock o2 sensors that is a waste of money.
Old 05-11-2004, 04:32 AM
kjewer1 kjewer1 is offline
AF - Advisor
Right. The question is not how acurate the AF guage is, or more accurately the O2 sensor voltage guage. It is perfectly capable of acurately reading the voltage signal from the stock sensor. Its the sensors signal that cant be trusted. Its a narrow band sensor, and was never intended for WOT tuning. Thats why the ECU ignores it entirely at WOT.
Now, a wideband is just that. Its a wider band. It can read typically from 10:1 to 20:1. The stock type sensors can only read 14.7, high by someamount, or low by some amount. 610 dollars? Most likely a wideband.
My advice is to save some moeny and go with a setup like the techedge I use (www.wb02.com). 300 bucks when all was said and done. And rather than using the expensive and hard to find L1H1 sensor, it uses a 28 dollar stock VW sesor, that happens to be wideband Very slick. I have have it setup so the output is datalogged in DSMlink so I Can review it later.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 05-11-2004, 10:30 AM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
which vw's have a wideband sensor? could you use on of the cheaper gauges with a wideband to make it more accurate?
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 05-11-2004, 04:00 PM
AF - Advisor
No, doesnt work like that The guages read barrowband sensors, 0 to 1 volt. Wideband sensors output 0-5 volts. Plus you need extra circuitry to maintain the temp of the heater element, etc.
Kevin Jewer
Old 05-12-2004, 11:30 PM
boostedinaz boostedinaz is offline
Send a message via AIM to boostedinaz
Re: Re: AIR/FUEL bad/good gauge
He is right. When people go to dyno they will have an A/F ratio, usually, at the bottom. That is read from a wide band O2. They are supper accurate and are the only way to really tell how well the car is tuned. The expensive ones you see are wideband and are that price becasue of all the necessary compnents that go into them. Alot have logging, memory, and a host of other functions that are helpful.
Michael
