Old 05-10-2004, 01:43 PM
ashcrx ashcrx is offline
zc parts
on the zc what header fits and also like plugs and wires and cap.thanks for the help.
Old 05-10-2004, 01:54 PM
Autocratic_1st_Gen's Avatar
Autocratic_1st_Gen Autocratic_1st_Gen is offline
Re: zc parts
any SOHC d-series header fits.
plugs/cap/wires for 1st gen teg , i think
i have a 91 Civic DX with 3x as much money in it as what i paid for it
i wish it was fast
here is my website
http://www.geocities.com/krustindumm/index.htm
Old 05-10-2004, 03:37 PM
tooslow911 tooslow911 is offline
Is it true that you have to port usdm d series headers to fit correctly on a ZC or it's just another false info spread on the web?
Old 05-10-2004, 03:52 PM
spongerlbc's Avatar
spongerlbc spongerlbc is offline
Send a message via AIM to spongerlbc
Re: zc parts
Taken directly from www.theZCr.com:
Stock Parts:
"-Head Gasket Integra 88-89
-Valve seals Integra 88-89
-Valve cover gasket Integra 88-89
-Cam oils seals Integra 88-89
-Intake Manifold Gasket Integra 88-89
-Exhaust Manifold Gasket Integra 88-89
-Main bearing Civic Si 89-91
-Connecting Rods Integra 88-89/Civic Si 89-91
-Pistons Integra 88-89
-Crank Shaft Integra 88-89/Civic Si 89-91
-Timing Belt Prelude Si 2.0 88
-Crank Seal Integra 88-89/Civic Si 89-90
-Rear Main seal Integra 88-89 /Civic Si 89-91
-Radiator Hose Upper Accord 84
-Radiator Hose Lower Civic 88-91
-Water pump Civic 88-91
-Oil Filter Civic Si 89-91
-Spark Plugs Civic 88-91
-Spark Plugs Wires Integra 88-89
-Oil Pan Gasket Integra 88-89/Civic 88-91
-Oil Pan Integra 88-89
-Oil Pump Integra 88-89
-Cam Gears All B serie and H23 DOHC
-Fuel rails Integra 88-89/Civic Si 89-91
-Thermostat Integra 88-89/Civic 88-91
-Couvercle de thermostat Integra 88-89
-Valve cover, bolt and Studs CRV 97-00/Integra All Ex.Vtec 90-01
-Fuel Pressure Regulator Integra 88-89/Civic Si 89-91
-Distributor Integra 88-89
-Distributor Cap Integra 88-89
-Crank Position Sensor Integra 88-89
-Injectors Integra 88-89/Civic Si 89-91
-Motor Mounts Civic Si 89-91
-EACV Integra 88-89/Civic Si 89-91
-Throttle Body Integra 88-89/Civic Si 89-91
-Gasket Throttle Body Integra 88-89/Civic Si 89-91
-Throttle Position Sensor(TPS) Almost all Honda (exc.DPFI)
Thanks to Garret for his list of stock parts!
Aftermarket parts:
-Kamikaze header
-NGK Integra plugs
-B&M FPR/Gauge *Universal*
-MSD system
-Rc 270cc injectors *OBD-0 or 1 available*
- EndynStainless valves
-Web camshafts
-Jun cam gears *TJ makes some as well, they are also cheaper*
-Power timing belt
-Dc header *88-91 top and 88-89 integra bottom works best*
-Endyn pistons *There are a variety or compressions for both NA or FI*
-Eagle rods
-Clutchmaster flywheel *Or any aftermarket flywheel for a 89-91*
-Any aftermarket clutch will work as long as its for a 89-91 civic unless your using an 88 transmition, same goes for flywheel*"
DOHC ZC 89 DX HATCH
Old 05-10-2004, 06:07 PM
CivicYoungin's Avatar
CivicYoungin CivicYoungin is offline
Send a message via AIM to CivicYoungin Send a message via MSN to CivicYoungin
Re: zc parts
since those stock parts fit zc can a aftermarket from the same engine fit the zc...
Example:
since a stock Cam Gears for All B serie and H23 DOHC fit the zc can AEM cam gears for any b serie fit the zc?
Old 05-10-2004, 07:37 PM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
Re: zc parts
Yes
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
Old 12-21-2004, 12:29 PM
jeffrule jeffrule is offline
Send a message via MSN to jeffrule
Re: zc parts
thanks spongerlbc exactly what i needed!!! i have a zc and its hard as balls to find parts for from parts stores(online) and other. this deff. helps
Old 12-21-2004, 02:54 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Also, heres a kick ass after market supplier for the zc ive gone through a couple times. Customer support is actually real good too
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 12-21-2004, 03:36 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
also, with the header. i've found an 89 teg header works good and needs very little porting to make work since ur using the 89 teg exhaust manifold gasket anyways.
Old 12-22-2004, 07:19 PM
spongerlbc's Avatar
Re: zc parts
A side note: the B-Series cam gear will work but the timing belt will not rest in the middle of the gear...it will be off to a side. To correct this simply shave (not sure exactly how much) the inner hub of the cam gears so the belt rides in the middle.
DOHC ZC 89 DX HATCH
Old 12-23-2004, 07:02 AM
1PhatCX's Avatar
i think i heard somewhere its like an 1/8 of an inch off
