do deloreans corrode?
does anybody here who has a delorean drive it in the winter where they use a lot of road salt? if so, does the body corrode or pit anywhere especially on the lower fenders, doors? just curious......
Re: do deloreans corrode?
As far as I know the body panels won't corrode, but things like subframes and underbody stuff like that will. Best to apply a liberal amount of undercoating and perhaps even wax treatment if you plan on driving in the winter.
![]() ________________________________________ Mark Brown 1991 Volkswagen Jetta (1.8L I4/5-speed/FWD)
Re: Re: do deloreans corrode?
The body panels are made from Alloy 304. Also, the Delorean is not a unibody vehicle. It has a frame that was coated (usually badly) from the factory with a layer of epoxy, I believe, though many people use a better rubberized or vinyl coating if they restore the cars.
Might I recommend www.projectdelorean.com to you - the guy is customizing while restoring, but it gives you a good look at some of the Delorean's construction.
Re: Re: Re: do deloreans corrode?
I wouldn't recommend a Delorean for daily driver winter use, but with proper care it's certainly capable.
I would never drive my DeLorean in an area that uses salt!!!
SOLID! crew (circa 2002). DeLorean moderator. |
As I recall, the body panels came with a 25 year warranty against rust. Obviously, it won't do much good since you can't exactly get warranty work done on Deloreans anymore.
10 PRINT "MARC-OS 0WNZ J00!!!" 20 GOTO 10 RUN 4/8/04 - My CRX is officially dead, RIP Lucy
