Old 05-10-2004, 01:26 PM
Josh278_2000 Josh278_2000 is offline
Car shakes rapidly at speeds of 50 mph and up
hello i am having some problems with my car and i have done many things to try to fix it. At speeds of 50 mph it will shake. When i let up on the gas it stops shaking and when i accelerate the shaking stops. Whenever i am at the same speed for a period of time it will start shaking. I have replaced a control arm, right drive shaft and had a high speed balance done on the front tires. 550 dollars later it still does the same exact thing. I am wondering can anybody help me
Old 05-12-2004, 09:09 AM
macpenguin13 macpenguin13 is offline
Re: Car shakes rapidly at speeds of 50 mph and up
i have a 95 grand am
i wish i had suggestions for you
my car does the same thing, but my speed is at 75 mph or greater.
Old 05-12-2004, 11:03 AM
jeter1955 jeter1955 is offline
try replacing plugs and wires.. this happened to my car and one of the plugs wasn't screwed in all the way this fixed my car... also try tightning the engine mounts..
Old 05-12-2004, 11:06 AM
by plugs do you mean spark plugs?
i have NO knowledge of cars
but im attempting to learn
scary eh?
thanks for your response i will check into that
Old 05-12-2004, 12:01 PM
Slade901's Avatar
Slade901 Slade901 is offline
Banned
What Year, Engine, etc?
Don't forget to replace your Fuel Filter.
When you replaced the control arm, did you replace the ball joint as well or the new control arm came in with a new ball joint?
Old 05-17-2004, 07:50 AM
Re: Re: Car shakes rapidly at speeds of 50 mph and up
It is a 94' with a V6 engine
Old 05-17-2004, 07:55 AM
CarSuperfreak's Avatar
CarSuperfreak CarSuperfreak is offline
Send a message via AIM to CarSuperfreak
Have you had the front end alligned? If that isn't the case, I agree with Slade, It sounds like a ball joint, or possibly a wheel bearing
Old 05-17-2004, 01:24 PM
no front end alignment i will try that ty.
I am also open to any other suggestions
Old 05-20-2004, 02:03 AM
junior59 junior59 is offline
I had a similar problem and it was my brake rotors. They are out of round and warped, buy some new ones and that will solve the problem. I would go ahead and change the pads while you are at it.
Old 05-20-2004, 07:29 AM
GASE 95 GASE 95 is offline
my 95 had similar problems but i just had to align the front end and it worked like a charm...i also bought new tires at the same time cuz the misalignment wore the old ones out
Old 06-04-2004, 03:51 AM
94greenbean 94greenbean is offline
Send a message via MSN to 94greenbean
i had similar problems with my 94 g/a
whenever i would drive between 50 and 60 and slighty cut the wheel left or right the car would shake terribly, as long as i drove straight it was fine. i had new front struts and new mounts put on and it solved the problem, it wasn't to costly. Maybe that might help?
Old 06-09-2004, 11:40 PM
rmlombar rmlombar is offline
Question Re: Car shakes rapidly at speeds of 50 mph and up
did you ever get this fixed. I have replaced tires, rotors, bushings, etc. and wheels. After 55 mph+ I get the same thing, it doesn't have anything to do with miss firing of spark plugs, but more suspension, balancing or something. When I hit these speeds my steering wheel and my dash starts bouncing like crazy. Please let me know if you have solved this problem because no mechanic can tell me what it is but I've fixed everything else... email if possible
Old 06-10-2004, 01:40 AM
Markgase2000's Avatar
Markgase2000 Markgase2000 is offline
Send a message via Yahoo to Markgase2000
try cleaning the inside of your wheels.
If its not clean CLEAN IT!!
If its not gleaming SHINER UP!!
If its not appealing BAG IT!!!
Old 09-05-2004, 10:41 PM
Eva Gina Eva Gina is offline
still having issues??
Hey,
I dont know if you are still suffering from numb hands, but my 95 was seriously having the same issue. I recently had a 2300 mile move for school and new i wanted the situation fixed. Turned out I had a bent/warped rim. It was causing uneven wear, strut issues, as well as the shaking. I got a replacement rim and Abracadabra.....fixed. I had taken the car in with those rims for rotating and balancing probably 5 times before they figured it out...so, maybe ask them to take a closer look at that next time...might just be one bad rim.
another alternative is to just try and have the front rims mounted on the back, this may take the shake out of the steering wheel and put it in your seat, which is sort of a fix, cause it wont be as obvious, however your still going to be putting excess stress on various car parts.
hope this helps
Old 09-08-2004, 11:52 AM
AcuraGirl AcuraGirl is offline
Spark Plugs and wires...mine had a hole in one of the wires, now it doesn't shake at all.
