Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 05-10-2004, 12:17 PM
Ragtop_Renegade's Avatar
Ragtop_Renegade Ragtop_Renegade is offline
Misfire
Now this is strange. 86' 4cyl 5 speed. The idle is a little rough but for the most part ok. Under power and mostly in higher gears the engine bogs down and sometimes will come back suddenly , usually when it hits 3000rpm or better. It really feels like a misfire. The plugs,wires,cap and rotor are all new and are ACDelco OEM parts, not the cheap kind.
One night I lifted the decklid in the dark after driving for 15-20 minutes and the exhaust manifold was GLOWING ORANGE. I thought this was a plugged up converter and the cause of the sluggishness but when I hacked off the old converter it was completly clear!!!!
Could this be a bad coil , or maybe a distributor pickup? Why does the manifold glow like that? Is it fuel from misfiring cylinders combusting in the manifold?
Even with 2 years of school and an automotive degree I am just plain confused here. I have seen one other car (a Celebrity) that had a glowing exhaust manifold and the converter was fine. That car was scrapped because we never did figure out why it did that.
Wanted to buy:
86-88 Fiero GT, 5 speed, fixer-upper. Blown motor, no motor? No problem! Rusty unibodies need not apply.
74-79 Ramcharger or 100, slant or no motor - not interested in v8 - Overdrive 4 is a big plus, NO hopeless rust buckets!!!
3Rd gen F body floor pans/camaro door skin (L)
Why is it I see so many "Proud to be an American" bumper stickers on the backs of cars made in Japan or Korea??????
Old 05-10-2004, 11:35 PM
RedFiero RedFiero is offline
Re: Misfire
Have you tried to adjust the heat range of the plugs? Maybe a cooler plug would work. I had a 65Malibu w/a 327/365 Vette Mtr. and the headers use to glow at night too, but it always did run extra hot.
Old 05-11-2004, 11:29 AM
Re: Misfire
On a newer stock, fuel injected, emmisions controlled engine there shouldn't be a reason to change the heat range of the plugs... Someone did mention my distributor might be 180 degrees out of time so I'll try re-timing the engine. When I pulled the distributor I noticed a lot of rust built up on the distributor pickup, that might be why it misfires alot and so randomly.
Wanted to buy:
Old 05-11-2004, 11:36 AM
Re: Re: Misfire
Ya when I bought my Fiero it wouldn't run because of the rust on the PU's. Mine was so bad that I had to replace the entire Dist. 180 degrees out of time I doubt that the car would run let alone overheat the manifold. Try the dist cleaning 1st. Good Luck R.
Old 05-14-2004, 11:34 PM
Re: Misfire
Well, the engine is retimed and the distributor cleaned up, the car does run much better but I still get that freaky orange glow off the exhaust manifold.... Don't know what could be causing it. Going to try swapping the coil as I have a spare. Could carbon buidup in the manifold make it do that? If carbon was that bad in the exhaust, I would think it would be just as bad in the head and the engine would diesel, but no. Anyone with any small idea please chime in
Wanted to buy:
Old 05-17-2004, 11:07 AM
fieronut fieronut is offline
Re: Misfire
hay... same problem i posted a new thread on that. i did an intake and perfectly in time i could bake a cake on the deck lid...sooooooo puzzled. glowing manifold WTF???
Old 05-17-2004, 11:09 AM
Re: Misfire
i can only think it is a timing problem. car was fine when i drove it into my shop
Old 05-18-2004, 02:28 PM
lakerfan1784 lakerfan1784 is offline
Send a message via AIM to lakerfan1784 Send a message via Yahoo to lakerfan1784
Re: Misfire
you most likely have a lean-burn condition, that causes the manifold to glow red. my friend's 87 did the same thing, although I cant remember what he did to fix it.
Do sober what you say you will do when you're drunk. that will teach you to keep your mouth shut.
