Old 05-10-2004, 12:12 PM
perna00's Avatar
perna00 perna00 is offline
Send a message via AIM to perna00
is this right!?
ok. i just took a hit to my ego. i have a 96' cav. with: 2.4 dohc engine, injen warm air intake, unorthodox underdrive crank pulley, header, free-flow cat., cat-back system, poly engine mounts, b&m shift+ kit, jet power control module, fresh air feed to the egr valve, and a recent tune up. i just raced a 98 cav. completely stock with the 2.2 non-ecotech. he beat me by about a car length. granted mine has about 100k miles on it and is an automatic, whereas his is a 5 speed with less miles, but i think i should have smoked his car. we both started at the same time spinning tires for a sec. is there something wrong with my car or what!?!
Old 05-11-2004, 04:22 PM
perna00's Avatar
Re: is this right!?
nobody has a comment?
Old 05-11-2004, 05:32 PM
blkcavi02's Avatar
blkcavi02 blkcavi02 is offline
Send a message via AIM to blkcavi02
Re: is this right!?
he has a 5 speed he controls when to shift therefore he can get speed faster than you can
Old 05-11-2004, 06:08 PM
studballs studballs is offline
Re: is this right!?
uh that was the stupidest thing i ever read blkcavi02...the auto with the shift plus will shift faster than any cavy 5 speed.
you should of beat him BAD with what mods you have...with what mods you have you are capable of a mid to high 15 second 1/4 mile...try removing that JET module...those things do more bad than good.
02 auto LS Sport 15.9@85
Old 05-11-2004, 08:59 PM
perna00's Avatar
Re: is this right!?
if i bypass it, the car still reacts the same. i'm also having other problems with my car that i think is the only other reason it could have beaten me. check out my other post and tell me what you think too if you don't mind "ok, i need some help now". thanks
Old 05-12-2004, 10:04 AM
fajita23200 fajita23200 is offline
Re: Re: is this right!?
I agree. If you are a good driver, you can do things with a stick that seem unlikely.
This above all:To thine own self be true,and it must follow,as the night, the day,thou canst not then be false to any man.(William Shakespeare)
Old 05-12-2004, 04:52 PM
perna00's Avatar
Re: is this right!?
so your think even with my mods the 5 speed is still quicker? seems almost unlikely that a tranny would make that much difference.
Old 05-12-2004, 10:51 PM
Re: is this right!?
dude even if you were totally stock an auto Z24 will beat a 2.2 ohv 5 speed...
