Old 05-10-2004, 10:18 AM
ssilver1 ssilver1 is offline
Angry #1 plug
How do I get the spark plug wire off the #1 plug and then get the plug out?
Old 05-11-2004, 08:04 AM
capoeta capoeta is offline
Send a message via AIM to capoeta Send a message via Yahoo to capoeta
Re: #1 plug
I assume and hope that you are referring to how you identify plug and wire #1. right?
If so, you have to look up in a manual to identify the firing order of your engine and go from there...
I don't have my manual with me right now but if you identify the engine size and year of vehicle I may be able to respond later.
Old 05-11-2004, 10:34 AM
Thumbs down
Sorry. I should have been more specific. What I'm refering to is:
On a 1997 Dodge Gran Caravan 3.0. I know where the #1 plug is. I can't get the wire off to get to the plug. I've tried using a wire puller. Didn't work.
Old 05-11-2004, 11:54 AM
slantsixness's Avatar
slantsixness slantsixness is offline
Re: #1 plug
it'll come off... but sometimes you have to sacrifice the plug wire....
try a pair of pliers on the boot, and get the boot to spin on the plug insulator. If it does come loose, then you can just pull it off, but even that's stiff to do sometimes.
You can get a new set of wires fairly cheap for the van, even if you don't replace all of them.
Since you're doing plugs and I'm assuming this is a '96 or later.., I'm not sure if you know yet, but access to the rear #2 & #4 plugs is from the underneath of the van, up through the exhaust cavity with an extension or two and a swivel socket. Replace these plugs using an old spark plug wire boot stuffed into a smaller socket so you can get them sarted back in the holes, then switch to the regular spark plug socket to tighten them ALWAYS COAT THE SPARK PLUG THREADS WITH ANTI-SIEZE before installation(permatex is best).
Use silicone grease around and in the hole of the spark plug wires when you reassemble. It'll make it much easier to do the next time.
good luck,
Slantsixness
If I knew what I did to break it, I would've known not to do what I did.
www.classicwinnebago.com
