Go Back   Automotive Forums Car Chat > Dodge > Stratus
Old 05-10-2004, 10:00 AM
helplessinarkansas helplessinarkansas is offline
'95 Dodge Stratus....won't stay running
The car runs for 10 minutes dies, cools off starts up. Tested all sensors, had a diagnostic twice. No answers. Replaced battery, new plugs, wires, coil pack, crank positioning sensor, oil pressure switch. Took off the gas tank and test fuel pump and filter. No idea what is wrong. It' a 2.0 engine, standard. HELP!!!
Old 05-10-2004, 11:38 AM
slantsixness's Avatar
slantsixness slantsixness is offline
Re: '95 Dodge Stratus....won't stay running
see if it runs when you hold accelerator to the floor when it won't "run".
Maybe Idle Air Control Valve... dirty or bad/clogged, hard to "test" if it's thermal related or intermittent.
That's my guess,
Slantsixness
If I knew what I did to break it, I would've known not to do what I did.
www.classicwinnebago.com
Old 05-10-2004, 11:40 AM
american rides american rides is offline
Banned
it's a dodge
it's a 2.0
it don't run
your better off
Old 07-12-2004, 09:13 PM
mechlabman mechlabman is offline
Send a message via Yahoo to mechlabman
95 Dodge Stratus won't stay running
I am now convinced that the main and a/c cooling fans for the radiator are why the engine and transmission act up after 10minutes or so of run time. I am going to wire up a circuit to the fan control relays to force them to stay on while the engine is running. I still cannot believe that Dodge put the ECM under the hood next to the engine exhaust. What a bone head design!!
