Old 05-10-2004, 09:47 AM
sct13 sct13 is offline
Bogging down on acceleration
Hi all, I havea Chevy S10 1991 4.3L injected. The problem is it will bog down on acceleration. I can get it up to speed but it will take a while. Two things, I cant properly check the timing as there is no emissions sticker and I can't find that info anywhere. Anyone got it? second I need to change the fuel filter (today) But I have adlusted the timing it runs better but it looks like its gettinig too much fuel when I open the throttle body. Which sensor might this be that regulates this? Any insight on this would help a great deal
Vic
Old 05-11-2004, 12:52 PM
turn4racing turn4racing is offline
Re: Bogging down on acceleration
my guess would be the throttle postioning sensor found on the back of the throttle body i believe
Old 05-11-2004, 02:12 PM
Thanx i will look into that, any Idea of the timing that is supposed to be on that sticker?
Old 05-12-2004, 11:25 PM
Vortec350S10 Vortec350S10 is offline
YOu first need to unplug a single wire to bypass the timing advance. this wire is located under the dash inside your truck on the passenger side. You'll see where the wiring harness passes through the firewall. The wire is tan with a black stripe I believe. It is next to all the other wires in the harness but is on the outside of the bundle with a little black connector on it. Simply unplug this and it puts the EST in bypass mode. Then take your timing light and time it at 0 degrees. When you unplug this wire your ECM will set a code 42- noted by your check engine light coming on. Once you time it, shut it off and plug the wire back in. Then unplug your ECM fuse for a couple minutes to erase the code. Then start it back up and your done! Simple as that.
