Old 05-10-2004, 08:40 AM
Young_gee Young_gee is offline
Send a message via Yahoo to Young_gee
Unhappy Rotors Lose? NORMAL?
hey guys i have a 98 GSX, I just had my both of my front wheel bearing replaced by the dealer. My question is when i remove my tires and breaks it's like the rotors are lose. You can easily push it back and fourth is this normal?
It's not how you stand by your car, it's how you race your car.
Old 05-10-2004, 08:45 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
tighten up your driveshaft/axle nuts(very center nut...23mm if i can remember right, but get it tight)...and make sure there is a cotter pin in the shaft so that it cant loosen again!
Old 05-10-2004, 09:43 AM
Re: Rotors Lose? NORMAL?
ok, here's a pic of the driver side rotor anything missing? www.angelfire.com/mn2/gees/index.html
Old 05-10-2004, 09:50 AM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
im not positive about the 2g eclipse but every car with disc brakes that ive worked on (1g eclipse, carollas, neons, skylarks, stratus, durango, grand caravan, etc...) has been this way
if i understand what your saying is that when you have your wheels off your brake rotors can shift back and forth. if you take off your calipers they can slide off the wheel hub completly the same way a wheel would when unbolted. if this is the case its normal. brake rotors are held on by the pressure of the lug nuts. with the wheel off theres no pressure so they're loose.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 05-10-2004, 10:24 AM
EclipseRST's Avatar
Banned
nope... looks just fine!
