Old 05-10-2004, 02:48 AM
Blandnuts Blandnuts is offline
Question A/C won't work
In my 98 Blazer, the a/c won't work any more. I still have everything else (heat, etc...) but when the a/c button is pressed the compressor never turns on. I replaced the climate control inside the car because it didn't light up the whole face anymore. I assumed that it shorted out and the whole control unit wasn't working correctly (still had heat and other controls just not a/c). Anyways, I'm back to where I started with a new climate control but still no a/c. I checked all the fuses and even bypassed the fuse to the compressor and managed to turn the compressor on (still would not blow cold air). I also bypassed the sensor that runs into the metal canister on the passenger side (don't know the name). It also turned the compressor without cold air blowing.
So what's the deal, is there another sensor that I should check? I don't have a wire diagram so I don't know if theres something right after the a/c button that's not completing the circuit. I don't know if it's because I have the "special a/c unit" with the auto controls that might be adding to the problem or what...
Any help would be great, considering I'm running out of ideas.
thanks
fred
Old 05-10-2004, 11:55 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: A/C won't work
You might be low on refridgerant
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 05-10-2004, 12:44 PM
Re: A/C won't work
I didn't check the pressure but when I did push the valve in, it did blow out coolant. Would that actually stop the compressor from turning over when I push the a/c button? I will check it again since I do have a recharge kit if it's low.
thanks
fred
Old 05-10-2004, 01:47 PM
GMMerlin's Avatar
I know stuff
Re: Re: A/C won't work
thanks
fred
Low pressure switch will prevent the compressor from engaging if the low side pressure is below a preset value...usually around 25 psi
GM WCT
PM Me for details
Old 05-11-2004, 03:28 PM
flytem3 flytem3 is offline
Had the same problem with my 95 blazer. Went to Pepboys and bought a can or R-134a with a hose already connected to it for $12 and put it in (follow instructions on can). You put the refrigerant in as the truck is running with the AC ON and as I was doing this, the condensor turned on and stayed on. Cold Air just as new for $12!
Old 05-11-2004, 04:20 PM
Re: A/C won't work
Hey thanks for the help, I just added some R134a and found where it was leaking. I might of fixed the leak but I won't know for sure till a few days. Thanks again.
fred
