Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 05-10-2004, 12:30 AM
96Civic_Coupe 96Civic_Coupe is offline
Banned
Quick Question, PLEASE HELP!!!
Im getting neuspeed sports. they drop the car 1.75 in the front and 1.5 in the rear and koni reds. i have searched and only found "maybe" to this question, but does anyone else have these springs and did u have to get a camber kit???
Old 05-10-2004, 01:17 AM
scallywag scallywag is offline
Re: Quick Question, PLEASE HELP!!!
probably not, but really all cars are different. What size rims and tires are you running. the bigger they are the more positive camber they will give you which is good becasue when you drop your car it will give you negative camber, so that could help to make the less negative camber. Really the best way to find out is to just have the car aligned (which you need to do anyways after the install) and they should give you a chart with your camber. What ever you do, don't buy a camber kit through the place that does your allignment. They will rip you off! If you need it in the back just do the bolt washer trick, and in the front go buy yourself a camber kit like ingalls off of ebay and then have someone install them, or do it yourself, You will save like $500 doing it this way.
Old 05-10-2004, 01:30 AM
Banned
thanks alot, i plan on getting 17's. I also heard that u should wait a week or so to let the springs "settle". should I?
Old 05-10-2004, 01:33 AM
BullShifter's Avatar
Civic's don't really need camber kits until 2" or more of lowering. For factory alignment specs you will need a camber with any lowering because there is no factory adjustment.
Old 05-11-2004, 09:36 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Neuspeed Sports are good springs. I'd totally recommend them. Paired to Koni Yellows they have a stiff feel that's close to how my Teins feel at 3/4th stiffness setting.
With the Koni Reds, they should have a nicer and more back friendly plush feel to them.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
