Go Back   Automotive Forums Car Chat > GMC > Jimmy
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 05-10-2004, 12:10 AM
dc9 dc9 is offline
bad brake vacuum booster?
95 4.3 w 4wd 122k miles
Replaced master cykinder,flex brake lines, new rotors, new pads, bled system, no air.
Brake pedal very mushy first half of travel with engine running.
Can hear air noise coming from brake pedal area, as i depress pedal.
Out of solutions, plz help!
Thanks.
Old 05-10-2004, 02:08 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: bad brake vacuum booster?
2 problems here...easy one first.
The air noise you hear from the brake pedal area is the sign of a booster leaking vacum
Mushy pedal.
Your truck is equipped with ABS...the ABS module will trap air internally...the bleed procedure is rather lengthy and you will need some GM special tools and a bi-directional scan tool to perform the bleed procedure correctly
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 05-13-2004, 01:04 PM
dc9 dc9 is offline
changed the brake vacuum booster and bled the brakes again. Seems like it fixed both problems: air noise gone and brakes feel alot firmer.Should i still have the abs module bleed done at the dealer?
Thanks .
Closed Thread
