Old 05-09-2004, 11:44 PM
dupeto_e's Avatar
dupeto_e dupeto_e is offline
car "bogs"
my car "bogs" when in gear and slowin down. i tried to do some research but nothing. it also smokes black after 4-4500 RPM's and smells like gas while cruseing.if any1 got a link or know something about it please post.appreciate...
Old 05-10-2004, 01:15 AM
FourG63 97GST FourG63 97GST is offline
Send a message via AIM to FourG63 97GST
what bov you have
-Agim
Old 05-10-2004, 09:38 AM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: car "bogs"
check the leaking headgasket thread to be sure but i think i saw somebody saw that black smoke usually means your turbo's dying
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 05-10-2004, 10:14 AM
dupeto_e's Avatar
Re: car "bogs"
its the 1g BOV. i think its fine.
as far as the head gasket i just put a 6 bolt with all new gaskets and oil seals.the only thing that i did not change was the valve oil seals(or whatever they call them).after doeing all that i realise that my stock turbo was fu..ed up ,so i boaght a newer one (t-25) from e-bay for 160$. the owner sad it had around 395** miles, around 40k. there was minimal shaft play ,very small, so i hope thats not the problem.
i think its the timming thoug, cuz the car accelarate kind of slow,retard. also could it be a leak?
Old 05-10-2004, 10:20 AM
Re: car "bogs"
do u have oversize injectors? what about any other mods you've done and have you installed the stuff youself or at a shop. give us a mod list. thanxs
-1stGenRocks-
Old 05-10-2004, 10:22 AM
Re: car "bogs"
oh and the valve seals could cause it to smoke but usually only when you first start it cuz oil leaks down into the cylinders through the bad valve seals
-1stGenRocks-
Old 05-10-2004, 10:59 AM
dupeto_e's Avatar
Re: car "bogs"
right(about the seals) and it would smoke kind of white if its seals (i think).
for mods i dont realy have anything. it appear thoug ,that the car has been mild modified before i got it. the side panel on the window(where u usually put your extra gages is missing, a hole bunch of wires are just shuved underneat the mat(under my feet and under the clutch).some wires attached to the O2 cable before the ECU(i guess its fuel/air ratio gage. also there is a little stand(braket) bolted under the wheel space for turbo timer or AFC maybe. under the hood the sugnificent differences were k/n filter, 1G BOV, 3" cat back greddy, i took the ballance shaft out,put a lightweight 6 bolt flywheel( ACT about 12 pounds,not alluminum) and thats about it.
i was sure 'til the other day that i got a bigger ingectors but ,no, they are the stock ones(at least it sad 450 on the side of them)
i do everything myself (first i like messin with my "baby" ,than i dont have money for servise).
after the swap the CEL run away(after fixin the coolant temperature sensor) and the only thing i havent done is set the timming properly (with a light gun or so) .the reason i dont do is cuz i'm not sure how to grownd the fuse u are supposed to grownd. so what i'm doeing now is twisting the CAS and driving around to see how it goes.
whats actualy the "boggin" is cosed of...
Old 05-10-2004, 11:36 AM
dupeto_e's Avatar
Re: car "bogs"
also my rear bumper(above the exsaust) is durty black (my car is black too lol) and there is like an oil spots.i can make a pic, but i only have the phone camera (duno if its goin to appear on it)...
Old 05-10-2004, 11:57 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: car "bogs"
SPELL CHECK!!! Wow...I think I killed about 20 brain cells trying to read that!
Old 05-10-2004, 12:34 PM
dupeto_e's Avatar
Re: car "bogs"
there u go again...mister "i can spell right".
dont tell me how to spell, go learn a second language or something,just like i did with english...stupid
Old 05-10-2004, 01:29 PM
Re: car "bogs"
Posted in the rules and regulations sticky (as dictated by Mr. RST)
Spelling... if you are going to type up a post and expect people to reply and know what you are talking about then spelling and grammar is a must! We are not really picky but if you do type as if you have certain way of talking and someone either bashes you or can’t understand what you are trying to say, do not get mad about it!
I am just asking that you please use a spell checker and some punctuation. It will make answering your questions much easier!
Old 05-10-2004, 01:53 PM
Re: car "bogs"
its not that horrible.
-1stGenRocks-
Old 05-10-2004, 02:07 PM
dupeto_e's Avatar
Re: car "bogs"
just like i sad before. if u dont get what i'm asking ,don't, again DO NOT reply.just pass it. obviously u are the only one who can't read it or have hard time. and PLEASE don't reply if u have nothing to say about why the car "bogs".NO1 IS ASKING FOR YOUR APPINION HOW I'M SPELLING. LOOKS, QVERHALL , THAT PEEPS KNOW WHAT I'M ASKING....stop bullshitting around and tell me why my car "bogs".
if u have no answer just shut your mouth and check the other treads .hopefully u learn something good...
Old 05-10-2004, 02:09 PM
dupeto_e's Avatar
Re: car "bogs"
for real man. i don't think is that bad at all.
1stGen do u have any clue why my car does that
Old 05-10-2004, 02:18 PM
dupeto_e's Avatar
Re: car "bogs"
sounds like 1400 cc Harley Davidson slowing down in gear ...
