Old 05-09-2004, 11:09 PM
97blazerct's Avatar
97blazerct 97blazerct is offline
Send a message via AIM to 97blazerct
leaking anti-freeze. !! HELP !!
i went to start my blazer tonight and it took a sec to catch, like it hesitated to start.. like old trucks do on cold days. Well i told my bf and he reved it a few times and warmed it up then i said UH OH i smell anti-freeze. Sure enuf its dripping out (only when running and sorta warm like 205degrees) from back behind the engine.. between the tranny and the engine really. It isnt the radiator bcuz its so far back, it doesnt look like its any of the radiator hoses (upper and lower anyway) and i looked @ my valves and head and it isnt leaking there. What could be a reason my truck is leaking anti-freeze when it warms up? It doesnt leak when its sitting shut off... A friend of mine mentioned if it isnt a hose that is hiden up there that i cant see it might be my engine block has a crack.. but what else could it be?
HELP ME!!
fords.. drive a chevy
My 1997 Chevrolet Blazer LS 4x4:
http://www.sounddomain.com/id/chevy4x4girl
Check out the pictures of her! Sign the guestbook and rate her good!
Old 05-10-2004, 10:52 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: leaking anti-freeze. !! HELP !!
HELP ME!!
Most likely the back of the intake is leaking.
Only a pressure test and a good look around will find the source.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 05-10-2004, 12:18 PM
Alexxn 00 Si Alexxn 00 Si is offline
Re: Re: leaking anti-freeze. !! HELP !!
What he said....mine did the same exact thing...turned out to be the intake manifold gasket. HTH
2005 Chevrolet Silverado 2500HD Ext cab
Old 10-13-2009, 11:28 PM
muddigger70 muddigger70 is offline
they have 2 freeze plugs in back of block between the engine and tranny,hope it isnt that,if it is you have to pull tranny back to replace.
Old 11-02-2009, 10:08 AM
91goldbomb's Avatar
91goldbomb 91goldbomb is offline
most likely the intake gasket mine leakes too aparently GM wasnt thinking when they designed the crappy paper gasket that goes in there
Old 11-02-2009, 05:54 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
Go to AutoZone and borrow the radiator pressure tester. It is a small hand held tire pump with a Radiator cap and Pressure gauge on it. When your engine is shut off and cold, remove your Radiator cap and attach the pressure tester. Pump up to the pressure rating of the cap. Then with a flashlight, you should be able to pin point the leak.
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr.
Old 11-19-2009, 08:48 PM
85sskid 85sskid is offline
If the intake manifold gaskets haven't been changed, I'll bet big money on those. Just changed mine on my 98 Blazer. Shop wanted $413 for shop and labor. I prolly spent about $75 for gaskets, oil, coolant, beers.
