Wiring Diagrams?
Okay I recently got a 84 944 and don' have an owners manual and can't find a haynes for it.
with my tailight problems and my rad fan problems, and alot of others(nothing seems to run and i wanna save as much as I can on labour) I am in need of a picture or diagram of the Fuse panels (labeled) so I know what fuses are for what..also I see a few relays under the dash..what are they for? anyone have any pics? regardz, Jeremy
1984 Porsche 944 1997 Mercedes-Benz C-Class 1988 Mercedes-Benz 190 |
In order from left to right
1 - Headlight low beam L 2 - " " " R 3 - " high " L 4 - " " " R 6 - stop lights, em flasher 7 - clock, int light, cig lighter, radio 8 - turn signal, brake warning 9 - backup lights, rear window wiper, outside mirrors 10 - fresh air fan 11 - windshield wipers 12 - License light, ashtray light, instrument light, luggage light 13 - side marker light L 14 - side marker light R 15 - fog light Upper fuses 1 - headlight retracter 2 - fuel pump 3 - radiator fan, antenna 4 - rear window defogger 5 - A/C condensor fan 6 - A/C compressor, fresh air fan 8 - power windows
83 - Porsche 944 - daily driver 62 - VW Karmann Ghia - never ending restoration project 95 - Ford Mustang - wifes |
Re: Wiring Diagrams?
It's about time I figured out how to post pictures.
![]() OOps upside down, so muchj for the quickie scan!
..wow that looks nothing like mine..there are wayyy more relay fuses than mine has..I think I seen 3 in my car...but I'll start pulling fuses to see how close that is..must be a big difference between the 83 and 84..also the roman numerals are weird..Mine also hasn't got those..would it be too much trouble to ask what color each fuse is?
Fuse amps, same order
1, 2, 3, 4, 6, 7, 8, 9, 11, 12, 13, 14 = 8amp 5, 10, 15 = 16amp Upper block 1 = 8 amp 2, 3, 5 = 16 amp 4, 6, 8 = 25 amp Relays are in numerals for less confusion 1 - cooling fan 2 - fuel pump/DME 3 - A/C 4 - headlight washer system 6 - rear window defroster 9 - horn 10 - intermittent windshield wiper 11 - turn signals Afterthought: you have no relays?
Not that many..
I will check again..I took it into a bosch mechanic
Thanks for the pics!!
