Old 05-09-2004, 11:34 AM
Helpme123 Helpme123 is offline
Z24 won't Start, need advice, mechanic can't figure it out
Could some one out there please help me figure out what is wrong with this car. I will give you some facts. First my car wouldn't start the fuel pump module made a weird noise, so I replaced the module with a new one. Still nothing. Then my mechanic assumed it must be the fuel pump, so I purchased one for $700 and it still wouldn't start. Then it was thought to be the computer. Replaced that, still nothing. Then we got someone to do a diagnostics on it and it said ignition, so I did that, and guess what, still won't start. If there is anyone who could offer a suggestion or two, it would be very helpful and very much appreciated by this girl who just wants to drive her car.
Old 05-09-2004, 11:38 AM
Oh ya its a 1997 Chevy Cavalier z24
its a 1997
Old 05-09-2004, 11:41 AM
-Jayson-'s Avatar
-Jayson- -Jayson- is offline
Re: Z24 won't Start, need advice, mechanic can't figure it out
sounds like you got a shady mechanic, did you take it to a dealership?
2009 Ninja 650 R
stock for now...
SouthEast Ecotec Enthusiast
Old 05-09-2004, 11:49 AM
Too scared tooo
I won't take it there because in Canada the GM Mechanics charge $73/hr and I'm sure my bill will come out to much more than the car is worth. But to be honest, the thought has crossed my mind. Thanks for the reply.
Old 05-10-2004, 01:19 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
OK let me get this straight..you dont want to spend 73 dollars to find out why your car wont start...but you have spent probally $1000 on parts that didn't fix it....makes sense to me
You need a couple things for an engine to run...air,fuel and spark
Next we need to see what is missing...and then go from there..
If the computer was replaced, was it programmed?
Did anyone check to see if you had power going to the fuel pump?
Do you have a crank signal?
Do you have power to the module?
Do you have spark?
Do you have fuel pressure?
Any codes stored in the PCM? BCM?
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 07-23-2004, 07:36 PM
Jugaboo Jugaboo is offline
If you haven't fixed this problem yet I might have an answer for you. I had a problem that was very similar to this. I was driving one day then the next I got up to go to work and my car wouldn't start. After consulting my mechanic I found out that it was my crankshaft position sensor. It's a relatively inexspensive part and fairly easy to replace. The only problem I had was that mine had snapped in half and I had to have my mechanic burn it out. I hope this helps you out . if not then I don't know what's wrong. Good luck :-)
