99 Regal LS power windows problem
Hi everyone,
All my power windows are not working. I replaced the switch assy (window lock switch was broken) and they still don't work. When I try to put the driver's window down, there is a screeching sound coming from the switch assy. All the other windows do nothing. Before this originally happened, I was having intermittent problems with the windows working at all. Any suggestions??? Thanks!! Last edited by ssknight77; 05-09-2004 at 10:35 PM. |
My 99 Regal Windows also not working
I bought a new switch myself. But what it was a loose or warn hot wire in between the firewall and the door. I Took the rubber boot off and searched, but didn't see anything. The thing I did to find out it was the wires in the door jam was I wiggled them and they all worked. That's it.
Re: 99 Regal LS power windows problem
Thanks for the reply. I figured it out. Open ground somewhere, so I rewired the ground wire from the switch to a nut on the door. Still works!!!
It broke at the base of the pivot point under the panel. Where did you get the replacement switch and how hard is it to do the job yourself? Any special tools? How do you get the bezel panel off where the switch 'sits'? I did a little poking around with the Bezel panel and was not successful removing the cover panel, really tried not to break it. Any help you folks can provide will be greatly appreciated. Thanks Richard |
Re: Re: 99 Regal LS power windows problem
