Old 05-09-2004, 08:18 AM
JimCRX's Avatar
JimCRX JimCRX is offline
Quick ? about PG7 ECU
I somehow found this when I was cleaning out my basement. I think it was my buddies cause it was still wraped up in bubble wrap and he bought one awhile back using my pc in my house so it got shipped to me I guess. Anyways, he has no use for it anymore. I heard before that people switch these ecu's with their stock D16A6 PM6 ecu. I have a d16a6 and a PM6 ecu. But I also heard that they can cause fuel flooding if you don't have enough mods. I have a exhaust(hollow cat. convert) and a intake and a few little things like spark plugs etc....Will this PG7 make any real difference if I put it in my crx? It's from a 89 integra i believe.
Old 05-09-2004, 10:39 AM
lilol89crx lilol89crx is offline
Re: Quick ? about PG7 ECU
put it in and try it.......then let us know
Old 05-09-2004, 03:06 PM
JimCRX's Avatar
Lol, yeah but I dont want to put it in if it will mess everything up. Cause isn't it from the 88-89 DOHC Tegs? Just that I read on crxsi.com that people said puttin it in your d16a6 will have more aggressive fuel cruves but can also be bad if you do not have enough air for it. So like I have a intake/exhaust and a few other small things. Just wondering if anyone has tried it?
Old 05-09-2004, 09:15 PM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
it definitely will run rich..no doubt about it. it runs rich in the zc as well...but people still do it..
SOLD!
Old 05-09-2004, 09:41 PM
well rich is always safer than lean.
Old 05-10-2004, 11:06 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
^Thats right. But the PM6 doesnt really run the car lean.I say just run it and see what you think. If you dont notice anything beneficial, stick with the PM6. It wont screw anything up.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 05-10-2004, 06:29 PM
marked001's Avatar
Moderadur
rich also means wallwashing... all the oil gets sprayed off the cylinder walls by all that fuel..
SOLD!
Old 05-10-2004, 08:27 PM
Re: Re: Quick ? about PG7 ECU
never thought of that...... but do you think the pg7 would make you run that rich over the pm6?
Old 05-10-2004, 09:02 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
How does that make any sense considering oil is down in the crankcase and the only way it could get into the cylinder in the first place is if you have bad piston rings or worn valve seals. At which point running rich is the least of your worries.
As for the PG7 running rich in ZCs that is a myth. Think about it. The ZC is nearly the same engine as the A1 but it does flow much better. So if it can get more air why would it run more rich.
Old 05-11-2004, 07:33 AM
marked001's Avatar
Moderadur
Re: Re: Re: Quick ? about PG7 ECU
so you're saying the rings just have metal/metal contact with the cylinders??
and its not a myth...stand by the exhaust of any zc running on the pg7 and it reaks like gas...its still the best bet besides the zc ecu....but he's not even talking about running in a zc.. he's talking about the a6.
SOLD!
Old 05-11-2004, 11:49 AM
89stdzc 89stdzc is offline
Send a message via AIM to 89stdzc
i have the zc and the pg7 i run 93 gas and my car doesn't run rich unless i'm @ WOT but any car should do that... i enjoy the pg7 i have used all 3 ECU's in my car pg7, pm7 and pg6 they are all about the same except the pm7 bogs out at around 115 or so.. i say put the pg7 in your car you'll like it. a friend has it in his stock car he races in scca stock-E he enjoys it
Old 05-11-2004, 01:23 PM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
Uh...I think the PM7 is the ZC ECU - it has a governor in it at 112MPH.
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 05-11-2004, 01:48 PM
JimCRX's Avatar
Suprisingly it runs great! It accelerates quicker. I drove it with the pg7 for a little and then put the pm6 back in and i noticed that it accelerates alot faster with the pg7. I guess I did have enough air to handle a little more fuel. It reaks like gas when I lay on it but thats probly due to my cat. converter being hollowed out.
Old 05-11-2004, 04:33 PM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
JimCRX i know i should PM u or start a new thread.. but did you feel a difference in gutting ur cat or did u loose low end torque? And how much did ur exhuast get that raspy sound?
Old 05-12-2004, 10:52 AM
sastanley's Avatar
AF Premium User
That raspy sound can sometimes come from not having a resonator in the exhaust system...usually between the muffler and cat. I had mine removed when I had my custom exhaust built, and I like it. For a li'l rice burner it sounds pretty good.
-Shawn
'91 Civic DX sedan
