Old 05-09-2004, 06:08 AM
jgeorg jgeorg is offline
Question Power Window Problem
My driver's side window just dropped one day while driving into the door and won't come back up. I can hear the motor working when I press the switch to go up or down. I opened up the panel and jammed the window closed with a piece of wood because I couldn't find the problem due the limited amount of space. One garage quoted $500 to repair it. The $10 lumber is more my budget. Any suggestions or advise is appreciated!
Old 05-09-2004, 12:44 PM
senaclinton's Avatar
senaclinton senaclinton is offline
Crazy enough the same thing happened to me Thursday. I was drivin' home, I heard a 'thunk', and my window just started sliding down (driver side, back window). So today we popped off the panel, looked at the inside, and I am lost. I've done this many times with my firebird...but this is beyond me. Any help will be greatly appreaciated before tomorrow. Tom. I will be taking it to the dealer for a quote on the fix.
(yr 2000, front passenger window doesn't work, driver window doesn't like to go up, and now this! Crazy thing, the back windows are hardly used, no kids, and usually only one person is in the car to even want to use the passenger windows)
You're stupid, until proven otherwise...
Old 05-09-2004, 01:08 PM
Re: Power Window Problem
Let me know how you do with this. I won't open my panel until next weekend. So if I find
out anything I'll let you know.
Good Luck!
Old 05-10-2004, 06:22 AM
tman's Avatar
tman tman is offline
Pimpin' ain't easy
Send a message via AIM to tman
I'm not into the technical words about this, but it sounds like the trolley that pulls and pushes the window up and down jumped the track. Pull the door panel off and take a look at it.
Old 05-15-2004, 03:34 PM
sallisonbrown sallisonbrown is offline
2000 Buick LeSabre Window Controller
The window assembly contains a continuous belt that raises and lowers the windows. I had to replace all four controllers with in 6 months at a shop cost of about $200 per controller. Not a hard job, but expensive!
Old 05-17-2004, 04:15 PM
PakanaHerruus's Avatar
PakanaHerruus PakanaHerruus is offline
Send a message via ICQ to PakanaHerruus Send a message via AIM to PakanaHerruus Send a message via MSN to PakanaHerruus Send a message via Yahoo to PakanaHerruus
i just purchased my car..85 LeSabre, and it has that problem, i found that the window guide was cracked...i can fix it, but i cant find the right replacement for it..autozone and advance auto have the track for every car but a Lesabre it seems, the engine is slow..but i only paid 350 for the car so im not to unhappy about it
