Old 05-09-2004, 04:39 AM
savanna's Avatar
savanna savanna is offline
Send a message via MSN to savanna
Need some help on my FC3S
Ok guys, its a work in progress, i basically just need to paint the whole body and the rims and finish off the taillights.
My problem is this, i kinda sprayed abit to much paint on the bonnet and its fucked, so can i sand paper it again to fix the uneveness of the paint and the tissue paper particles that happened to get stuck on when i tried to white the paint off
also can someone link me to where i can get a tutorial on how to make an exhaust, and do u guys have any tips for lowering and putting a camber on the wheels.
it has turning front axis so yea, if that gives u an idea of the problem and that i have no idea how to lower it.. so yea any help would be appreciated. Cheers dudes.
Old 05-09-2004, 06:06 AM
SupaMan89T's Avatar
SupaMan89T SupaMan89T is offline
Send a message via AIM to SupaMan89T Send a message via MSN to SupaMan89T Send a message via Yahoo to SupaMan89T
Re: Need some help on my FC3S
i hope these help you.Yes sand the hood with 1000 grit and then redo it. heres the links you asked for-
http://www.automotiveforums.com/vbul...hreadid=107458 <<< lowering FAQ
http://www.automotiveforums.com/vbul...threadid=89854 <<exhaust FAQ
i hope this helps you im looking forward to seeing it.
Project Lexus Revive
Old 05-09-2004, 06:29 AM
savanna's Avatar
thanks for the help about the exhaust and paint, lowering is a different issue, as this model came with a electic motor, so the chassi is very different, i.e no shocks, ive had to go very dyi on it and have basically converted the chassi to work with the plastic middle of a cotton bud (ear bud) that way i can bend it to give the illusion of a camber and being lowered. you cant see it unless u lift it up so i guess its ok, theres not other way to do it really.. unless u guys know of any..
ill post some pictures onces its finish.. the white rims r looking nice tho i must say.
Old 05-09-2004, 08:28 AM
SupaMan89T's Avatar
wow i hope it comes out good for you im waiting to see it.
Old 05-10-2004, 02:12 AM
savanna's Avatar
ok i sanded it down and began spray painting, but the paint seems very rough, will it be ok if i sand it down again and give it a few more coats.. at the moment the paint job is extremely rough..
Old 05-11-2004, 01:44 PM
suprastar's Avatar
suprastar suprastar is offline
did you prime the the sanded surface?
vroom?
Old 05-12-2004, 12:08 PM
DJPaul DJPaul is offline
Prime it first and them warm the paint before painting
