Old 05-09-2004, 02:31 AM
hardleft hardleft is offline
Unhappy engine swap
i can't seem to get my 350 chev in. took out a 301. do i have to move motor mounts foward or what? 1979 t/a
Old 05-09-2004, 03:25 AM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
Re: engine swap
well you should be able to tell by looking....
Old 05-11-2004, 01:30 AM
Wink
had a close look! totally different mounts, bolt holes don't even come close. good thing i have a welder, because those mounts will never move again, its only a thundercar anyway: have a good day
Old 05-11-2004, 07:31 AM
JoeJoe231455 JoeJoe231455 is offline
Re: Re: engine swap
Please drop that 301 engine in an ocean so it can't disgrace the domestic community any longer
2001 Pontiac Grand Prix GTP
1994 Pontiac Firebird Formula
1972 Pontiac GTO
Old 05-11-2004, 08:34 PM
69bird 69bird is offline
Send a message via ICQ to 69bird
301 Pontiac to 350 Chevy
You need V8 frame mounts from second generation Camaro 70-81. remove your 301 Pontiac frame mounts. holes are already there. You can hold the chevy frame mounts on sub frame and see which holes line up. Firebird and Camaro uses the same front sub frame. holes are there for both chevy and Pontiac engines. If your using an auto trans. you'll need one for chevy, pontiac is different.
Old 05-16-2004, 02:04 AM
LMB LMB is offline
Send a message via AIM to LMB
Remove 301
Throw out 350 chevy
Find 455 Pontic and drop in....
Old 05-20-2004, 12:48 PM
MrPbody MrPbody is offline
AF -Advisor
LMB is right! That small block will get embarassed badly, the first time you line up against a "real" Pontiac V8. You could have bought and built a strong 400 Pontiac for about the same money. If you bought upgrades for the Chevy, you paid even more!
BTW, you'll need an adapter or a different transmission, too. Was that 301 a turbo? If so, the parts are not worthless.
