Old 05-08-2004, 09:43 PM
1992RS 1992RS is offline
Send a message via Yahoo to 1992RS
The wrong way that works.
Well had a bit of some car trouble this week. Woke up tuesday morning and the car wouldn't start. Did the quick trouble shoot and found that fuel wasn't getting to the injectors. Turns out the fuel pump wasn't cutting on. Checked all the fuses, ran the ECM for codes so I decided that the pump was bad. Now, the right way to change the pump would be to drop the exhaust, suspension, and rear end. The wrond way, the way I did it, was to drop the exhaust and wonder bar, cut a hole in the car right above the tank, drop the tank onto the rear end and go from there. I made a clean cut with an angle grinder with a cutting blade, cleaned it up real nice and then tacked on a piece of sheet metal. All of this cuz I didn't have anything to syphen 13 gallons of gas into....lol Turns out the pump wasn't the problem. I was pissed. Checked the relay, it was good, rechecked fuses and ECM all good. Turns out the oil pressure switch was fried. Now ain't that a bitch..lol
Old 05-08-2004, 09:48 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: The wrong way that works.
lmao!!!!! ahhh sheet... cest la vie man jumpin to conclusions sucks. im tryin not to do that with my IROC right now and the VATS problem.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 05-08-2004, 09:51 PM
Well the fucked part is, I did it by the book. Why the hell is the fuel pump inline with the oil pressure switch? Whoda thunk it.
Old 05-08-2004, 09:53 PM
89IROC&RS's Avatar
well comon man, thats an easy one. its a safty deal, if you aint got no oil pressure, you dont want the engine running now do ya. so if there is an open circuit to the oil pressure switch, and the comptuer cant monitor the pressure, then its not gonna let the engine run now is it
Old 05-09-2004, 02:42 AM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
sometimes.. to find out whats wrong with the car.. you have to Think like the car?
1991 Camaro Z28
Old 05-09-2004, 01:55 PM
While I understand your point, I still don't understand the logic behind putting the fuel pump inline with the oil pressure switch. It would make so much more since if possibly the ignition was in line with it. Or at least put the Oil pressure switch in the trouble shooting matrix in the manual. Oh well, problem solved and I have some brand new parts.
Old 05-09-2004, 07:36 PM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
yea, just be happy its done and over with now, and you dont have to worry about replacing it for a long time
Old 05-09-2004, 11:41 PM
true that
