Old 05-08-2004, 08:19 PM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
head gaskets
i was putting on my head gaskets tonite and noticed that the water passage is restricted by the gasket, my water passage on the block and heads is about quarter size, maybe a little bit bigger on the block, now the gasket allows only about a size of a pen through, i was wondering if anyone has cut the gasket? and it it would help the heads run cooler
Old 05-08-2004, 08:29 PM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
personally i have never heard of it being done b4, did you order the gaskets engine specific? or just general as in small block or big block? if u ordered them as a general type of gasket, it may have to be cut. but either way if it is blocking a flow point, it makes sense to me that you should cut it...
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 05-08-2004, 08:34 PM
Re: head gaskets
yea there for a standerd sb 350, fel pro makes them, i was temped to cut them i jus came in to see if anyone else has because the water passages on this block are bigger then my old one
Old 05-08-2004, 11:20 PM
vettemaan's Avatar
vettemaan vettemaan is offline
Send a message via ICQ to vettemaan Send a message via AIM to vettemaan
Re: head gaskets
I was thinking the same thing, Proabably shouldnt cut em.
Old 05-08-2004, 11:21 PM
406Elcamino 406Elcamino is offline
Re: head gaskets
The holes are different sizes to control the coolant flow through the block and heads. Do not cut them. You will have cooling problems.
Old 05-08-2004, 11:46 PM
oops too late, i knew i shouldnt have worked on this under the influence, but these hole were small as shit, not even a mm in diameter, i cut them to 3/4, what kind of coolent problems should i expect?
Old 05-08-2004, 11:53 PM
vettemaan's Avatar
Re: head gaskets
i was thinking it might cause you to blow the gasket (Get cooland in your cylinders) but i dunno.
Old 05-08-2004, 11:55 PM
Re: head gaskets
ive replaced a few head gaskets and dont remeber this, i coulda sworn the coolent holes on ther other gaskets were bigger..... god i feel dumb now, cause i cant remember....
Old 05-08-2004, 11:59 PM
Re: head gaskets
You can experience flow that is too fast and the heat from the cylinder walls and heads won't have time to be absorbed by the coolant. Causes hot spots. Can lead to cylinder wall problems also. Cylinder can go out of round.
Old 05-09-2004, 12:12 AM
f*ck f*ck f*ck f*ck f*ck
Old 05-09-2004, 12:27 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: head gaskets
did you already put it all back together?
Old 05-09-2004, 12:29 AM
Re: head gaskets
no but i got the damn heads torqued on, and im anxious to put the bitch in the car
Old 05-09-2004, 12:32 AM
Genopsyde's Avatar
The President
Re: head gaskets
well just un-torque em and fix your problem, haste makes waste, know what I mean.
Old 05-09-2004, 12:34 AM
Re: head gaskets
damn right, i jus got the block machined and got it back bout 2 weeks ago
Old 05-09-2004, 12:40 AM
Genopsyde's Avatar
The President
Re: head gaskets
just make sure you're sober this time.
