Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 05-08-2004, 05:17 PM
bishonabike bishonabike is offline
It Keeps Cutting Off
My 1988 Wrangler starts and idles fine. However, after I drive it a few minutes and it warms up, it starts dying every time I stop at a light. I've changed every vacuum hose and some ignition components. While it's running, it's great, but whenever I stop it dies. It restarts fine, but it will not idle once I put on the brakes. This is so frustrating. Can anybody help me with some ideas?
Old 05-10-2004, 11:52 PM
Axe91CVC Axe91CVC is offline
distributor? or distributor cap?
ok hrrmm ..i dunnno....its getting spark to start??? soo???
clogged fuel filter???
worn out fuel pump???
Old 06-09-2004, 11:21 PM
tvnoll tvnoll is offline
Re: It Keeps Cutting Off
Hey I have a 97 Wrangler and the same exact thing is happening to me. I dont know if you've fixed the problem yet, but try checking the idol speed control valve. That's the problem with my jeep.
Old 07-27-2005, 11:26 PM
smfleming smfleming is offline
Jeep dying at stop light..
I have the same problem..did you ever find out what was causing this?
Old 06-06-2008, 01:30 PM
cfrank2 cfrank2 is offline
It sounds like your idle air control(IAC) valve has gone bad, this valve controls how much air your engien takes in while your jeep is idling. Sometimes they just get dirty but cleaing them will usually finish them off too so i would just replace it. the part will probably cost less than $50
