Old 05-08-2004, 05:19 PM
TheCrazzyOne TheCrazzyOne is offline
86 astro, Need help fast
ok. recently the ignition system went out, replaced the coil, distrubutor, and a few other things.
Now when we time it, it will idle just fine, but as soon as we aply any pressure to the accel it just makes all kinds of noise and vibrates like crazy.
Seems like a computer issue to me, but i am completly clueless on how that timing advance crap works. This is my dads van and we have had several people come out and check it out.. now one knows(not mechanics, just friends who know alot about cars)
its like the timing is just right untill you aply gas then it starts firing way to soon, but if we back it down untill that stops, the car just dies, no mater what position the distributor is in it still does it.
Please help soon, need it runing by monday.
4.3 litter tbi (dont think its the same engine the van was built with)
ill reply in a min with more info, gota find number on block to identify motor
Old 05-08-2004, 08:48 PM
CD Smalley CD Smalley is offline
Re: 86 astro, Need help fast
Did you disconnet the... what's it called... ESC wire? It's a brown&tan wire that must be disconnected when setting the timing...
Did you do this when you set the timing?
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 05-09-2004, 12:27 PM
Re: Re: 86 astro, Need help fast
yes.. and with that thing off its almost imposible to time it, it vibrates so much and the timing jumps up and down so much its imposible to get a acurate read with the timing light.
Cant find number on engine, so cant identify engine, but we think that we may have it off by 180, so we are going to try that now. Ill reply as soon as we finish to let you all know if it worked or not. incase it dosnt work please post any other ideas you may have
Old 05-09-2004, 02:33 PM
Re: Re: Re: 86 astro, Need help fast
k, its not 180 off or any thing, but there are to markings for timing, tried them both. they both run the exact same, how the hell is that posible?
Please any ideas? need help!..
Old 05-09-2004, 07:59 PM
Not sure on the two timing marks. You're talking about two marks on the balancer right?
Pick the one that the distributor needs the least input from. I mean the least amount of advance, turning it clockwise to advance it. Then tighten the dist. down and hook up the ESC wire.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 05-09-2004, 10:10 PM
74 Cricket 74 Cricket is offline
Try astrosafari.com
