Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 05-08-2004, 03:39 PM
Motttocs Motttocs is offline
Caliper Bolt Star or Torx What size?
Anyone know the type and size bit to remoce the calipers for a 98 Dakota 2.5L?
Old 05-10-2004, 07:22 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: Caliper Bolt Star or Torx What size?
It's an allen key that undoes the calipers.
Old 05-31-2004, 08:39 AM
newsmile_7 newsmile_7 is offline
Re: Re: Caliper Bolt Star or Torx What size?
It is a 7mm allen head.. Get one that you can use on a ratchet it will make it easier to get them off and on. Also when you remove them be carefull not to damage the rubber bushings they are in.. You also can get new ones at most auto part stores.
Old 05-31-2004, 08:41 AM
it is a 7mm allen head...
Old 05-31-2004, 08:07 PM
BleedDodge's Avatar
Echo?
Old 06-09-2004, 10:01 AM
slantsixness's Avatar
slantsixness slantsixness is offline
It's a 7mm allen head...
Is that clear now?
If I knew what I did to break it, I would've known not to do what I did.
www.classicwinnebago.com
