Old 05-08-2004, 12:11 AM
Eclipsester Eclipsester is offline
Serious Question.
Have you guys heard about Electric Turbo/Supercharger run on 12v. battery? Does those thing really work? had anyone in this forum has it?
Old 05-08-2004, 12:20 AM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: Serious Question.
No, nobody here has it, or will ever buy one of those ebay scams. This is not a serious question.
Old 05-08-2004, 12:24 AM
1g redline's Avatar
1g redline 1g redline is offline
Send a message via AIM to 1g redline
nope dont waste your time joe said it best
what would god do if he had a turbo?
Old 05-08-2004, 07:50 PM
Julioluko Julioluko is offline
Yeah i was wondering about those too, because the idea makes sense. what makes it bad?
Old 05-08-2004, 07:53 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
to spin the blower motor takes power. to get the power means using the alternator more which takers power away from the engine and since nothing is 100% efficent you will lose power at the alternator, and at the blower as heat. got it?
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 05-09-2004, 12:01 AM
thanks 1stGen
Old 05-09-2004, 01:40 AM
helliviknow's Avatar
helliviknow helliviknow is offline
Send a message via Yahoo to helliviknow
if your talking bout the cheap ones on ebay uhrm yeah dunt tink so... they blow what 350cfm? if u ask me if its not measured in psi its not feasable.. iv seen somethin called a e-ram however.. but like 1stgen said it draws power and runs the alt. the eram gives u a proven 1 psi and i think i heard on a stock civic 1.5 it was like 8 hp on the dyno or something. but that also has a 700 watt 55 amp engine.. so thats gonna have ur alternator on overdrive.. meaning its gonna suck whatever power it makes right back out through the alt. id just play it safe and go the 16g route
Old 05-09-2004, 01:49 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
lol it doesnt have to be measured in psi to work... 350cfm is more air flow than the stock T25 has! so it might work, never tried it, would be interested in seeing how it works but you would definately need an upgraded fuel system!
