Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 05-07-2004, 10:48 PM
kkiepvvessau kkiepvvessau is offline
Send a message via AIM to kkiepvvessau Send a message via Yahoo to kkiepvvessau
Prelude doing crap .... help
start up engine leave it warm up , engine sound fine but
if i press the gas (just one and leave it running) the engine idle going up and down , engine sound crap . if i press the gas couple time and hold at 4ooo rpm for 40 second the idle back to normal ...
One thing i know is like water coming out my exhaust every morning. the place i park now all black ... anybody have this problem before please help .... i think is cooling problem. Radiator i drain , refill and leave run 10 min i did like 5 time but no help different day .. now give up
help needed thanks
Old 05-14-2004, 01:06 AM
DropSquadCivic DropSquadCivic is offline
Send a message via AIM to DropSquadCivic
Did you bleed you fluid? Because sometime air in the engine will do that because i think you iacv reads the temp of you radiator fluid and if there is an air bubble the sensor doesn't understand. The iacv might be bad too.
93 cx- H22
