Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 05-07-2004, 08:20 PM
catcher catcher is offline
loud screeching noise on starting
car : toyota corolla '95
Problem : I am getting a loud screeching noise from the front
whenever I make turns on starting after a long rest and goes away after few minutes of driving.
any ideas ?? something needs a change ??
thx
p.s: I changed front brake pads couple of months back.
Old 05-12-2004, 04:10 AM
Toyrolla's Avatar
Toyrolla Toyrolla is offline
Send a message via AIM to Toyrolla Send a message via Yahoo to Toyrolla
Check your power steering.
Make sure the power steering reservoir has enough fluid.
Also check your power steeering belt for wear, it might need to be replaced.
Once this areas are checked, you can bleed the system by slowly turning left all the way, then right all the way.
If neither of this works, then you may need a new power steering pump..
Good luck,
Regards,
Nobody can break it better than me.
88 I4 Slushie, 89 I4 5Sp, 89 V6 5Sp, 82 Corolla, 72 510, 88 Minitruck.
