Old 05-07-2004, 06:04 PM
Urban_Squrill's Avatar
Urban_Squrill Urban_Squrill is offline
Send a message via AIM to Urban_Squrill Send a message via MSN to Urban_Squrill
420a parts
I am trying to put together a parts list that I need to rebuild my self a new motor and all the other things that I will need(ie turbo set up, tranny stuff, springs..ext.) But I am having a really hard time finding parts for a 420a. Also with my rebuild/turbo I was wondering what parts do you think would give me my target of 350hp.
Old 05-07-2004, 06:18 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: 420a parts
420a is the 1.8 liter engine right? i can sell you every part except that the rear silent shaft and the journal for it in the block is screwed up that what happens when you throw a silent shaft bearing and drive around for a week trying to figure it what the fuck that knocking noise is
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 05-07-2004, 06:21 PM
Re: 420a parts
It is the 2.0/
Old 05-07-2004, 06:26 PM
Re: 420a parts
are you sure about that i thought that 4g63 was the 2.0L and just they changed a couple things between the turbo and nt but the engine number was the same
-1stGenRocks-
Old 05-07-2004, 06:36 PM
duckydsp's Avatar
duckydsp duckydsp is offline
The 420a is 2.0
DSF
1998 Green Mitsubishi Eclipse GS- Vibrant Ram Intake, Greddy Evo2 cat-back, front and rear strut bars.
2 Kicker L7s, amp coming soon
17" white Motegi RT5 rims, Quwhees 12-piece wide-body kit will be put on....... someday
Old 05-07-2004, 06:52 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Re: 420a parts
There both 2.0
And 350 is not going to be easy at all. That is about what Jake is at, so yea good luck
For Sale 98 Eclipse GS, 5 spd
Old 05-07-2004, 06:57 PM
Re: 420a parts
so what's the 1.8
-1stGenRocks-
Old 05-07-2004, 06:59 PM
ashah000's Avatar
Re: 420a parts
One of the 1g's
Old 05-07-2004, 07:38 PM
Reckage Reckage is offline
Re: 420a parts
Would you say 300 hp is just as hard or more uptainable
Old 05-08-2004, 11:35 AM
HotCrew's Avatar
HotCrew HotCrew is offline
Send a message via AIM to HotCrew
Re: 420a parts
I think 300 or even 350 could be arranged it is just a matter of money and proper tuning but so is pretty much everything.
Check out my site
After Night Groove Team Site
RS-T Build Up Site
http://www.angelfire.com/pro2/rst
Old 05-08-2004, 11:37 AM
HotCrew's Avatar
Re: 420a parts
But even if you are not putting out quite that much a 420a is an interesting machine. It will almost always put out more torque than horsepower and that will be the deciding factor
Check out my site
RS-T Build Up Site
Old 05-18-2004, 05:45 PM
95EsiTalonAT 95EsiTalonAT is offline
Send a message via AIM to 95EsiTalonAT
Re: 420a parts
These ppl r not rt....420a can make upto/over 400hp..don't believe/trust me...then go see my friends at Hahn racecraft...plus with there kits u get everything..say u want 350hp i think that is a stage 3/4 kit and includes the rods/pistons too plus u can start at stage one for bout 2grand then spend 800 more to upgrade to stage 2 and so through all the stages...if you need more help contact me cuz i'm currently building my car and will share any info/knowledge i have.
Old 05-18-2004, 05:54 PM
ashah000's Avatar
Re: Re: 420a parts
No one said the 420a can't make 350 or 400hp we said it is NOT easy.
Old 05-18-2004, 06:22 PM
Re: 420a parts
its a money factor more than anything and lots of time if you do it yourself. But can anybody point to a proper list of the steps to take when modding a stock rs/gs and what is the max hp you can get going all motor on a 420a motor keep in mind the compression must be kept low to accomadate a turbo setup as the final step after all motor mods possible have been done. Or where do they sell engines already maxed out on all motor power.
Old 05-18-2004, 07:16 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: Re: 420a parts
LMAO!!!
wow nice english! WTF is... "These ppl r not rt" ?... if your goin to post, use the english language and correct spelling!
as for stage 3/4 kit is 350hp... um maybe at the crank stage 4 is 350hp! and once you hit that it does not come with everything you need... does it have valves, springs, cams, injectors, fuel pump, AFC, boost controller, exhaust... i could go on and on with this!
trust me buddy i researched this for about 8 months before i even started buying stuff... if you build your own kit its much cheaper! if i would have went thru Hahn for all my shit i would be sitting at around $8-9000 instead of $5000! and i got 350whp + 100 shot of nitrous... please explain how Hahn is better if you must!
