Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 05-07-2004, 01:13 PM
kingcarm kingcarm is offline
changing the manual trans fluid
I want to change my manual transmission fluid and was wondering if someone can recommend what transmission fluid I should use. Also is there anything I should know about as far as changing the trans fluid or is it just a matter of draining the old fluid and refilling with the new fluid? Any thoughts are greatly appreciated.
PS....I just got my 240 painted and it looks GREAT!!! pics coming soon!
Carm
My 1991 240SX SE
Old 05-08-2004, 01:59 PM
Re: changing the manual trans fluid
Wow, I guess no one ever changes their Trans. fluid. 17 hits and no replies.
Carm
My 1991 240SX SE
Old 05-08-2004, 02:31 PM
dimitri_ dimitri_ is offline
I don't like ununswered posts much.
According to the the Chilton repair manual the fluid should be changed every 30K mile or 24 months...now let me see...I had my car for 11 years, it's at 117K miles and I am trying really hard to remember if this was ever done!!!! hmmm...
Anyway.
Drain it after the engine has reached normal operating temperature.
Use fluid with an APO GL-4 rating, however I don't have anyhting more specific on that.
Watchout for the OIL coming out. It will be HOT!
You'll have to use a long nose funnel or a baster to fill it unless the bottle has a long skinny neck.
Would love to hear from someone who has actually done this, what fluid they used and if shifting actually changed as a result....
anyone ...anyone...
Dimitri
Old 05-08-2004, 03:57 PM
MIKECORPSINC MIKECORPSINC is offline
Cool
NOW I GET SO MANY CARS IN MY SHOP I CN'T REMEMBER IF YOU HAVE TO PULL THE SPEED SENSOR TO FILL THAT OR NOT???
NEVERTHELESS, I ALMOST USUALLY DO, FILLING THE FLUID TO THE BOTTEM OF WHERE THE SPEED SENSOR GEAR SHOULD B.
OH, MAKE SURE THE CAR IS LEVEL WHEN DOING THIS, common mistake
Old 05-08-2004, 05:30 PM
Thanks guys. I did notice the fill hole is on the side of the transmission I am going to use one of the funnel's with a long tip to refill the fluid after I drain. I'm wondering if the drain plug and fill plug are going to be a bitch to get off. I mean, they 've probably never been removed.
Carm
My 1991 240SX SE
Old 05-08-2004, 07:07 PM
Toksin's Avatar
Toksin Toksin is offline
Non-profit Organisation
Send a message via AIM to Toksin
Just check if they have crush washers or not, you'd want to replace those or you'll end up with a nice little leak
I think you can use Caltex Texamatic, I'm sure it meets those grades, but it would be best to check your manual or your nearest oil distributor.
Old 05-08-2004, 10:37 PM
thelinja thelinja is offline
Send a message via AIM to thelinja
The plugs are removed using a a 1/2" drive ratchet. Be sure to remove the fill plug first (just incase you can't get it off after you drain the oil). Also, I don't think a funnel will reach down that far. I just went to Home Depot and got some vinyl tubing and made an oil bong.
As far as oil goes, any GL-4 75w90 or 80w90 gear oil will work. Don't use GL-5, as it is corrosive to brass syncros in the tranny.
Old 05-09-2004, 05:48 AM
SR20DETpower SR20DETpower is offline
Banned
Send a message via AIM to SR20DETpower
I answered this in another post recently, but I agre with thelinja
75w90
Old 05-09-2004, 09:16 AM
Thanks again Guys!!!
Carm
My 1991 240SX SE
Old 05-09-2004, 02:08 PM
vsiev vsiev is offline
Send a message via AIM to vsiev
do you have a fsm? if not get one...link in my sig
EDIT: I mean link is in my sig lol
Hiya...
Need a FSM? Hit me up I'll send it to ya for FREE!
I only have the 91-98 240sx, s13 ca18det, and s14 sr20det FSM
Sorry no 89-90 yet....
Mods:
Tein Flex with EDFC
Hotshot Header
R32 GTR Seats
Advan SA3 16x7 16x8
Apexi Dual N1 Exhaust
Silvia Front End Conversion
Digital Climate Control
Nismo 2-Way LSD
Injen Intake w/ CAI
