Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 05-07-2004, 11:24 AM
west50 west50 is offline
Question ac charging question
I'm wanting to charge the air in my truck. I have the manifold gauges and a 30lb. cylinder of 134a. what I can't remember is where the low and high side pressures should be on these gauges. i'm thinking high side 150-200 and low side 30-40 is this correct. haven't had to charge one in awhile
Old 07-13-2005, 09:01 PM
electech59 electech59 is offline
Re: ac charging question
Use a scale and charge the quantity listed on the MFG label affixed under the hood. Ususlly around 2lbs. The low pressure side will generally read around 35 - 55 psi when fully charged and under load. The high side will be anywhere below 250 psi. Remember all pressures vary dramatically dependant on ambient conditions and system loading.
Old 07-16-2005, 05:49 AM
Blylock Blylock is offline
Re: Re: ac charging question
he is absolutely right, AC pressure is based on ambient temperatures, and there is no set pressures for charging any AC unit, on cars or home. depending on how warm or cold it is on that day, will reflect on your charging pressures.
1998 Ram 1500 SLT 4x4
5.9L
Dynomax Performance Dual Exhaust
KN cold air intake
Bosch +4 Platnum Plugs
180 Degree Thermostat
I would suggest to anyone with a Ram to convert to a performance exhaust, especially if towing alot.
