Old 05-07-2004, 10:19 AM
faulnh faulnh is offline
1998 Tahoe P0102 code - please help
Hello, my name is Nathan. I am new to the forum. I own a body repair shop (as a hobby and for extra income). I specialize in Corvettes and Trucks.
I recently purchased 2 - Tahoes at auction (1998 & 1997). Each have the service engine light on. One vehicle stumbles off idle then runs ok. The other (which I am focused on in this thread) idles well, but stumbles when the pedal is pressed quickly. Also, when the engine warms up, it will not pull a hill or accelerate over 20mph on level ground.
The OBD codes indicate a faulty (P0102) MAS and Cam Position Sensor. I erased the codes and replaced the MAS with a new unit from Chev..(I bought the CPS but have not installed it yet). Both faults remain and there is no change in performance. I didn't expect the CPS fault to go away, but I am stuck on the MAS fault. My Question: What else is in the MAS circuit could cause the fault to return (I checked connections at the MAS and swaped the MAS from the other Tahoe w/o luck).
This weekend, I will change the fuel filter, ERG valve, CPS & Spark plugs, but I know these changes will not help the P0102 fault.
Thank you for any advise on this,
Nathan
Old 05-09-2004, 07:00 AM
michelq michelq is offline
Re: 1998 Tahoe P0102 code - please help
Sound like blown fuse or no power to sensors, check the wiring
Old 05-09-2004, 07:55 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
DTC P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency
Circuit Description
The mass air flow (MAF) sensor is an air flow meter. The control module supplies the MAF sensor a signal circuit. An ignition positive voltage circuit and a ground circuit are supplied to the MAF sensor by independent circuits. The MAF sensor heats a wire element, or grid, within the MAF sensor in order to maintain a calculated temperature. As inlet air flows across and cools the grid, the MAF sensor increases current flow to the grid in order to maintain the constant grid temperature. The MAF sensor converts the grid current flow into a frequency signal. The control module converts the MAF signal frequency into a grams per second value. During low air flow rates, such as at engine idle, the MAF sensor produces a low frequency signal. During high air flow rates, such as at wide open throttle-road load, the MAF sensor increases the frequency signal. The control module monitors the MAF sensor signal frequency in order to calculate the flow and mass of the air entering the engine.
This DTC is designed to detect an unusually low MAF sensor signal frequency. If a MAF sensor frequency is detected by the VCM below the possible range of a normally operating MAF sensor, this DTC will be set.
Conditions for Running the DTC
The engine run time is more than 0.4 seconds.
The engine speed is more than 300 RPM.
The system voltage is more than 8 volts.
Conditions for Setting the DTC
The MAF frequency is 10 Hz or less for more than 1 second.
Action Taken When the DTC Sets
The control module illuminates the malfunction indicator lamp (MIL) the first time the diagnostic runs and fails.
The control module will set the DTC and records the operating conditions at the time the diagnostic fails. The control module stores the failure information in the scan tools Freeze Frame/Failure Records.
Conditions for Clearing the MIL or DTC
The control module turns OFF the MIL after 3 consecutive drive trips when the test has run and passed.
A history DTC will clear if no fault conditions have been detected for 40 warm-up cycles. A warm-up cycle occurs when the coolant temperature has risen 22°C (40°F) from the startup coolant temperature and the engine coolant reaches a temperature that is more than 70°C (158°F) during the same ignition cycle.
Use a scan tool in order to clear the DTCs.
Diagnostic Aids
Check for the following conditions:
A misrouted harness. Inspect the MAF sensor harness in order to ensure that it is not routed too close to the high voltage wires such as spark plug leads.
A damaged harness. Inspect the wiring harness for damage. If the harness appears to be OK, observe the scan tool while moving connectors and wiring harnesses related to the MAF sensor. A change in the display indicates the location of the fault.
A plugged intake air duct or filter element. A wide open throttle acceleration from a stop should cause the Mass Air Flow displayed on a scan tool to increase from about 4-7 g/s at idle to 100 g/s or more at the time of the 1-2 shift. If not, check for a restriction.
An intermittent may be caused by any of the following conditions:
A poor connection
Rubbed through wire insulation
A broken wire inside the insulation
Thoroughly check any circuitry that is suspected of causing the intermittent complaint. Refer to Intermittents and Poor Connections Diagnosis in Wiring Systems.
If a repair is necessary, refer to Wiring Repairs or Connector Repairs in Wiring Systems.
Test Description
The numbers below refer to step numbers on the diagnostic table.
This step verifies that the problem is present at idle.
A voltage reading of less than 4 or more than 6 volts at the MAF sensor signal circuit indicates a malfunction in the wiring or a poor connection.
This step verifies that the ignition feed voltage and a good ground are available at the MAF sensor.
This step determines if the fuse is open. If the fuse is open, locate and repair the short to ground in the ignition positive voltage circuit.
Step
Action
Value(s)
Yes
No
1
Important
Before clearing the DTCs, use the scan tool Capture Info to save the Freeze Frame and Failure Records for reference. The control module's data is deleted once the Clear Info function is used.
Did you perform the Powertrain On-Board Diagnostic (OBD) System Check?
Go to Step 2
Go to Powertrain On Board Diagnostic (OBD) System Check
2
Start the engine.
With the engine idling, monitor the MAF reading on the scan tool.
Is the MAF reading below the specified value?
2 g/s
Go to Step 4
Go to Step 3
3
Turn ON the ignition leaving the engine OFF.
Review the scan tool Failure Records data.
Record the scan tool Failure Records data.
Operate vehicle within the Failure Records conditions as noted.
Using a scan tool, monitor the Specific DTC information for DTC P0102.
Does the scan tool indicate that DTC P0102 Failed This Ignition?
Go to Step 4
Go to Diagnostic Aids
4
Inspect the MAF ignition positive voltage fuse.
Is the fuse open?
Go to Sep 11
Go to Step 5
5
Objects blocking the MAF sensor inlet screen
Crankcase ventilation valve malfunction, missing or incorrectly installed.
Vacuum leaks in the following areas:
Throttle body
EGR valve flange and pipes
MAP sensor seal
EVAP canister purge valve seal
Fuel meter body seal
If a problem is found, repair as necessary.
Did you find a problem?
Go to Step 17
Go to Step 6
6
Turn OFF the ignition.
Disconnect the MAF sensor harness connector.
Using a J 39200 DMM, measure the voltage between the MAF sensor signal circuit and battery ground .
Is the voltage near the specified value?
5.0 V
Go to Step 7
Go to Step 10
7
Connect a test lamp between the MAF sensor ignition positive voltage and ground circuits at the MAF sensor harness connector.
Is the test lamp ON?
Go to Step 9
Go to Step 8
8
Connect a test lamp between the MAF sensor ignition positive voltage circuit and the battery ground.
Go to Step 12
Go to Step 13
9
Check for a poor connection at the MAF sensor.
Repair the circuit as necessary. Refer to Connector Repairs in Wiring Systems.
Go to Step 17
Go to Step 14
10
Check the MAF signal circuit between the VCM and the MAF sensor for an open, short to ground, short to the MAF ground circuit, or short to voltage.
If the MAF signal circuit is open or shorted, repair as necessary. Refer to Wiring Repairs in Wiring Systems.
Go to Step 17
Go to Step 15
11
Check for a short to ground in the MAF ignition positive voltage circuit.
Repair as necessary. Refer to Wiring Repairs in Wiring Systems.
Replace the open fuse.
Is the action complete?
Go to Step 17
12
Check the MAF sensor ground circuit for an open.
Go to Step 17
13
Check the ignition positive voltage circuit to the MAF sensor for an open.
Go to Step 17
14
Replace the MAF sensor. Refer to Mass Air Flow (MAF) Sensor Replacement .
Go to Step 17
15
Check for a poor connection at the VCM connector.
Go to Step 17
Go to Step 16
16
Replace the VCM.
Program the new VCM. Refer to VCM Replacement/Programming .
Perform the VTD Password Learn Procedure. Refer to Password Learn Procedure .
Perform the CKP System Variation Learn Procedure. Refer to CKP System Variation Learn Procedure .
Go to Step 17
17
Using the scan tool, clear the DTCs.
Start the engine.
Allow the engine to idle until the engine reaches normal operating temperature.
Select DTC and the Specific DTC function.
Enter the DTC number which was set.
Operate the vehicle, with the Conditions for Setting this DTC, until the scan tool indicates the diagnostic Ran.
Does the scan tool indicate the diagnostic Passed?
Go to Step 18
Go to Step 2
18
Does the scan tool display any additional undiagnosed DTCs?
Go to the applicable DTC table
System OK
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
