Old 05-07-2004, 08:33 AM
BlackSpyder1998 BlackSpyder1998 is offline
squeking noise
Hi im new to this forum and I had a quick question could any one tell me what a squeking noise in my front right tire. it make it all the time but it stops if i press the brake just a little bit. I had my rotor resurfaced and i installed better brake pad but it still make that noise you thing it might be that bearings I will appreciate any answer Thankyou!!
Old 05-07-2004, 10:46 AM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: squeking noise
sounds like your brake pad could be dragging
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 05-07-2004, 07:00 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: Re: squeking noise
the same thing happened to me after i got brakes a while back [i'm on my 3rd front set in about a year, this was my 2nd set i'm talking about, rear is still the OG green stuff's]. i confered with my mechanic and was told to do some pulls with some advanced breaking [only after you have broken in the breaks to begin with] and that will even the pads down. my breaks were smoking when i did it... LOL that may be a bit too much, but it worked!!!
Old 05-07-2004, 07:02 PM
Re: squeking noise
could you explain advanced pulls? do you mean just speed up then brake or speed up while brakingwhat do you mean?
-1stGenRocks-
