Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 05-07-2004, 07:04 AM
sdanville sdanville is offline
2000 Silouette. Ok Campers, who's changed their spark plugs ?
I read the engine has to be tilted to replace the rear plugs?
I bought my plugs last year. Not prepared to take off the engine mounts. I'd be willing to grind down a socket. Anyone here change their own plugs ?
3.4 V6 2000 Silouette
Old 05-07-2004, 10:41 PM
Bill V Bill V is offline
Re: 2000 Silouette. Ok Campers, who's changed their spark plugs ?
The engine must be pulled forward (after removing the front dog-bone mounts). Be prepared for back, neck, and arm pain as well as misc. cuts and abrasions...
Old 05-08-2004, 07:36 AM
Re: Re: 2000 Silouette. Ok Campers, who's changed their spark plugs ?
Pulled forward ? So i need a ceiling Beam, chain, pully and a couple fat buddies to pull ?
Old 05-21-2004, 12:33 PM
bottomtech bottomtech is offline
The rear plugs can be accessed from underneath, if you reach up past the exhaust pipe on either side.
Old 08-21-2004, 08:24 AM
Spark plugs - rear bank from bottom side.
Now thats what forums are for.
Some guys are pulling their engines and your telling me I just have to jack it up and go from the back.
THANK YOU ! ! !
[email protected]
Old 08-22-2004, 10:23 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
There are a couple ways to do this job..you can loosen the front "dog bone" mounts and shift the engine forward (all you are doing is tilting the engine no removing it) or you can go in from underneath.
BEWARE...you may find it diffcult to remove the plug wires from the plugs..twist them untill they loosen then remove the boot from the plug.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 09-15-2004, 06:09 PM
shaneland shaneland is offline
just changed my plugs yesterday.
I reach in from the top over the TBI and down the back. I have changed them from underneath as well. Underneath is easier as you can see what your doing.
Make sure you secure the wires as the often lay on the exhaust!!!
Old 09-15-2004, 06:14 PM
Tbi ?
[quote=shaneland]just changed my plugs yesterday.
What is the TBI ?
Old 09-15-2004, 09:38 PM
Yours is a piece of cake (a '93). The 2000 and up version with the "E" code 3.4l engine is a back breaker.
Old 09-15-2004, 10:08 PM
throttle body injection...
Old 09-15-2004, 10:10 PM
Wink Re: Re: 2000 Silouette. Ok Campers, who's changed their spark plugs ?
sorry for the lack of paying attention...
Old 12-07-2004, 01:41 PM
Kawdog Kawdog is offline
Getting ready to replace my '97 Olds Sihouette plugs, and have a couple of questions ...
1) Does your advice apply to the '97 Silhoutte's, also ??
2) Does the engine need to be supported from above (ie., with a strap or chain from an engine hoist or overhead beam, when the front ("dog bone") engine mounts are removed ??
3) Which method (removing the engine mounts, or accessing from below) of removing/replacing the plugs would you recommend ??
Thanks in advance ...
Old 06-11-2005, 12:03 AM
swimmin_mensan swimmin_mensan is offline
How do you replace from below? I have jacked up and can't find where to access plugs. Do I have to remove anything to acces plugs?
Old 06-11-2005, 03:58 PM
cdru's Avatar
cdru cdru is offline
From below, you can access them by reaching up through the opening where the exhaust pipe comes out. You will need to jack up the car a considerable amount of distance though. I found it just as easy to remove the ignition modules (hint...once you remove it, never put the nuts on the rear studs...makes the next time alot easier) and going at it from the top. I'm a husky guy with big arms and hands, and it's a really tight squeeze to get under the vehicle as well as fit my arm up in there. I just go at it from the top.
I've done it enough times for various repairs on the back half of the engine that it only takes a jiffy to pull the ignition module to get easy access to everything back there.
My steps:
1. Remove both dogbones
2. Use a ratchet belt strap (for tying down cargo) and thread it through the loop on the right, front corner engine support bracket going through the hole where the hood latches down. (other locations are available too). Tigten down slightly.
3. Remove the middle link of the wiper arm assembly.
4. Remove spark plug wires from ignition module.
5. Remove two front bolts and 2 rear nuts. You may need to rock the engine forward slightly make room for the rear
6. Rock engine back if you moved it forward already. Remove ignition module and set aside.
7. Change rear plugs. A universal joint and/or a stubby ratchet wrench may be helpful.
8. Reassemble is the opposite order.
Old 06-11-2005, 09:43 PM
diesel1962 diesel1962 is offline
Hello.It took me three hours to change plugs in my 97 olds van.Bought it used ,And the plugs were original from the factory.They were in there for 158,000!!.Had to use P-B Blaster oil to get them to loosen up.It was like they were welded into the heads! You can get to plugs from underneath the vehicle.You cannot really see them very well,But you can do them by feel.Good luck, Diesel 1962..
