Old 05-07-2004, 04:47 AM
95mugenaccord 95mugenaccord is offline
Red face Need Help with Shifter....!
i had a fourth gear failure for bout three months after i replaced my clutch. i always thought the mechanics did a bad job and i needed a new transmission. Yesterday i was messin with the shift knob and it went into fourth. i asked my friends and they said i should jus get a new shift knob. How do i go about it and which ones should i be lookin into?
Cars. . . Food. . . and Women . . . WaT doeS LiVing MeaN tO YoU?
We'Re noT all GuraNteed TomorroW, So LiVe toDaY aS iF it WeRe YouR LaSt. . .
Drive Fast, Race Hard, and Much Luv to aLL Ya'll OuT there.
GoOd LucK to YouR asPiraTioNs.
Old 05-10-2004, 05:46 PM
wheel1856's Avatar
wheel1856 wheel1856 is offline
Send a message via AIM to wheel1856
Get a Helmes/Haynes/Chilton manual first.
A shift knob is just a pretty thing on top of the shifter. It is not responsible for your gear failure, and the mechanics may still be.
How exactly are you having this fourth gear failure? are you:
a. unable to ever shift into 4th, car off shifting for fun, or car driving
b. unable to shift into 4th at high rpm's
c. unable to shift into 4th at low rpm's
d. sometimes it shifts, sometimes it doesn't
e. it grinds for a second but goes in
e. you have recently installed an aftermarket quick shifter and now it misshifts all the time
what did the mechanics replace? just the clutch? flywheel? shift linkage? get a list.
unfortunately, there is a lot that could be wrong here, without knowing the whole situation, it is difficult to assess the situation. lil more info would be a great help
"Why yes, this is a GS-R."
Old 05-27-2004, 08:48 PM
Civic_D16Y5's Avatar
Civic_D16Y5 Civic_D16Y5 is offline
Send a message via AIM to Civic_D16Y5
Re: Need Help with Shifter....!
hmm, my 1st and reverse gears are semi hard to get in sometimes because the mechanic said the bushing had xpanded slightly but was nothing to worry about
http://www.carsponsorships.com/scout/sponsor.php?id=737
GET SPONSORED, QUICK
