Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Cosmetics
Cosmetics interior, exterior, wheels.
Old 01-15-2002, 05:39 PM
P10player P10player is offline
Question performance is lagging
ever since i put on my 18" rims my ride has been slower. then a piston rod broke in my engine, and my cv joints went bad in my right side are these all because of my rims or not. and what can i do to improve my performance on my car?
Old 01-15-2002, 09:38 PM
Dshaft96 Dshaft96 is offline
18" rims are usually big and heavy, so what do you expect? Swap in a SR20DET.
Old 01-15-2002, 11:17 PM
nis.k.a.'s Avatar
nis.k.a. nis.k.a. is offline
The motor has to put out more unneccessary effort to move a bigger wheel. More effort is also required to move a heavier wheel. Being a bigger wheel means the gear ratios are off, thus giving you the slower pick up. The extra weight makes the car struggle more at the moment of inertia and use more power to keep the drive wheels turning. So basically, you're straining your motor to look good. Of course, a modded engine helps, not as much as if you removed those 18's in favor of 15's or 16's.
nightmaR3Z
Old 01-16-2002, 02:42 AM
JustinP10's Avatar
JustinP10 JustinP10 is offline
Send a message via ICQ to JustinP10 Send a message via AIM to JustinP10 Send a message via Yahoo to JustinP10
If you get, or read Sport Compact Car Magazine, they had some good write-ups on understanding how wheel weight affects a car's performance. The math wasn't perfect, but it gave you a good idea of what to expect. I'd guess it was about a year or so ago they published this stuff? It was in technobabble or the slip angle, i can't remember off the top of my head at the moment. Hope this helps.
Justin McClanahan
95 G20
15.4 @ 91.4mph (2.4 60ft )
143.7whp and 131.4 ft.lbs
Primera (10:1) Intake Cam, HS CAI, HS Header, UR Pullies, 19* Timing, ACT, Lightened Stock Flywheel, GC/AGX, Pacesetter Short Shifter, and more stuff...
Old 01-16-2002, 12:56 PM
Mrcoilover Mrcoilover is offline
Or 17's. That would be you best bet for performance and looks.
*Mod List*
2 JL audio W3 12's
Rocksford Fosgate 600w amp
Tein type NA (1.7)
Nokya Arctic purple headlight bulbs
Rims coming soon...
"I always ride dropped, how bout you?":finger4:
Old 01-16-2002, 05:10 PM
nis.k.a.'s Avatar
Not best for all around performance. A 16 with a 45 is probably the better happy median.
nightmaR3Z
Old 01-17-2002, 09:16 AM
But you forgot about looks.
*Mod List*
2 JL audio W3 12's
Tein type NA (1.7)
Rims coming soon...
