Old 05-06-2004, 11:13 PM
gardnrstreet gardnrstreet is offline
help
i have a 2000 ford taurus, i recently borought it to the shop for a diagnosis.the problem is a pinging noise when accelerating or going up hill.the emissions light has come on but does not stay on consistently.the diagnosisis as follows...
Customer states check engine light on and pings upon acceleration and up hills..connected a scan tool, retrieved code PO402.Tested the DPFE sensor signal=1.6 volts.Tested the DPFE reference voltage and ground O.K. Tested the EGR valve operation , the valave opens,the passages are clear.Ran the KOER Self-test while monitoring the BARO,ETC,IAT O2 sensors and fuel trim pids.All readings normal.Verified engine ping under load. Need to perform Upper engine decardon.Also noticed spark plugs are worn.Fuel filter also needs replaced. COST 700.00 - 800.00$
I told him he was crazy
how hard is it to replace dpfe sensor does the above dianosis seem accurate, i do not trust dealership mechanics as far as price and amount of work goes.should iuse procees of elimination try one thing at a time.i know basics of cars and could do the fuel filter,spark plugs myself.one thing i should add is that the car seems to run with less ping at night,cooler temps.please help.
Old 05-07-2004, 01:14 AM
zx2srdotnet's Avatar
zx2srdotnet zx2srdotnet is offline
Banned
Send a message via AIM to zx2srdotnet
Re: help
what gas do you run? might be that you need higher or lower grade, my moms sable only pinged under load if the fuel grade was to high
Old 05-07-2004, 02:27 PM
Re: help
ude 87 octane, manufacturer sugguested.tried running premium octane and still had the ping.
Old 05-09-2004, 07:04 PM
irish30's Avatar
irish30 irish30 is offline
Re: help
The DPFE sensor is very easy to replace. The reference voltage should be .75 to .9 volts. The engine pings because it is running too lean. When the engine is cold the PCM with adjust the fuel trims to richen the fuel air mixture based on engine temp and ambient temp. If the fuel air mixture is more rich the engine runs cooler, this reduces the ping. Replace the DPFE sensor, and disconnect the battery for .5 hour to clear your eng light.
Old 08-30-2004, 04:53 PM
nascaracing nascaracing is offline
Re: Re: help
Ok, I understand all that, but where on the 2000 Taurus is this sensor located?
Old 09-01-2004, 08:18 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: help
does this taurus happen to be an FFV?
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
