Old 05-06-2004, 11:06 PM
r8erz4life r8erz4life is offline
Question 1 wheel drive?
I have a friend who has a '97 V6 Mustang, and he claims that he has one wheel drive. (I believe it's the right rear). I told him he is full of s**t, but I don't know anything about Mustangs. Am I wrong or is he an idiot?
Old 05-06-2004, 11:08 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Well hopefully he's just pulling your chain. Otherwise, yeah, he's an idiot.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 05-06-2004, 11:11 PM
GrahamGT GrahamGT is offline
COul dbe th efact thhat he has an open slip so the power goes to the wheel with th e leas friction
Beating a mustang in a race is like winning the special olympics, even if you win your still retarded.
sidrone sidrone is offline
Re: 1 wheel drive?
I think mustangs do not have lsd... so maybe your friend did a burnout and only one wheel was spinning due to open differential and so he thought that his Mustang was 1 wheel drive... someone correct me if i'm wrong...
Old 05-06-2004, 11:12 PM
SikNingStang SikNingStang is offline
Send a message via AIM to SikNingStang
Re: 1 wheel drive?
he probably thinks it's 1 wheel drive b/c in his V6 he doesn't have posi or limited-slip so it will only burn 1 tire when he tries to powerbrake it so yea he's an idiot... unless he's just missing the left axle so it will only run 1 tire but otherwise considering all is well in the rear end... it's probably b/c he can only do a burnout with 1 tire
Old 05-06-2004, 11:13 PM
Re: 1 wheel drive?
I was going to suggest that it was a possible open differential cause I didn't think v6's came with traction-loc. I could very well be wrong though.
yea mine would do that
Old 05-06-2004, 11:14 PM
SIKCRX SIKCRX is offline
Re: 1 wheel drive?
lern who two speel
but yea,
if you were to jack the rear end of the car up and hit the gas both wheels would turn, right?
2.3L pumpin out 105 stock horses, WHAT NOW BISHES
Old 05-06-2004, 11:16 PM
It might be a '96. Would that matter?
Old 05-06-2004, 11:17 PM
Re: Re: 1 wheel drive?
the '02 v6 i had, had it on there
Old 05-06-2004, 11:19 PM
Originally Posted by SIKCRX
lern who two speel
but yea,
yes because the is very little friction in teh air
it only matters really in a skid situation , or burnout
Old 05-06-2004, 11:22 PM
Re: Re: Re: 1 wheel drive?
ok problem solved...your friend was trying to be a smart ass b/c only one of his wheels does a burnout. and he was going to bet you. he gives mustang owners a bad name.
Old 05-06-2004, 11:24 PM
So he is an idiot then?
Old 05-06-2004, 11:26 PM
Re: 1 wheel drive?
that would be correct. if you want to earn some money place a bet. then jack his car up like i said before and tell him to hit the gas.
technically,now that i think about it, if only one wheel was to spin then the car would drift to the side, its like rowing a boat but only rowing on one side.
Old 05-06-2004, 11:28 PM
That's what I told him. I said he would do circles if he was right. Thanks for all the input, now I can print this up and shove it in his face.
