Old 05-06-2004, 10:05 PM
Mike Ulin Mike Ulin is offline
door panels
I recently purchased a '93 Grand Am that needs some window work. How do I get the door panels off?
Old 05-07-2004, 02:02 AM
matt919's Avatar
matt919 matt919 is offline
Send a message via AIM to matt919
Re: door panels
there are a few screws. Most of which are around the outside lining of the panel. one on the side, and two or three under. These are Phillips head screws. There is also a Torx screw in the section of the door handle/lock. also, there may be one screw underneath the arm rest on the door. With these out, the door will remove more or less easily, but you should watch around the handle and the lock, because you have to maneuver it around them.
Old 05-07-2004, 08:17 AM
chaz132 chaz132 is offline
thats it if you have power windows, if not there is a little clip that holds the window retractor handle on. this is a pain to get off, I have been told there is a tool to get it off, you might want to try getting one, or just spend about 20-30 mins with a very small flathead screw driver, and no small childern around, because you will probably be cursing like crazy every time you almost get it.
Old 05-25-2004, 12:06 AM
derffred's Avatar
derffred derffred is offline
Re: door panels
you can also try using a rag by sliding the rag between the window crank and the door panel, sliding the rag back and forth should pull out the clip
Old 05-25-2004, 07:25 PM
Thanks to all who replied. My apologies for leaving out some important details(like it's a two door coupe w/power windows). After some extended searching, I finally found a long silver screw underneath the base of the handle around the center of the door, more or less. Both panels are now off and I'm planning to install new regulators. Thanks again!
Old 05-26-2004, 09:20 AM
GASE 95 GASE 95 is offline
Re: door panels
yeah man, that long sucker under the arm rest got me too. Took me probly 3 days to figure that crap out...pshh
Old 06-04-2004, 03:33 AM
tiltthe63s tiltthe63s is offline
Send a message via AIM to tiltthe63s
Re: door panels
There is a tricky screw located in the door lock and handle assembly
