Go Back   Automotive Forums Car Chat > Land Rover > Discovery | LR3 | LR4
Old 05-06-2004, 08:18 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
Squeeking From Drivers Side
ok my bro has a 97 discovery se...
whil driving at low speeds it starts making a squeeking noise from what sounds like the driver side tire...i could be wrong....but anyways, itz the sound like when ur brake pads have worn and are rubbing on the rotor...but the brakes are new and the rotors are fairly new...itz odd b/c it happens while driving....wondering if u guys can help me out on this problem
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 05-07-2004, 09:59 AM
Cbass94's Avatar
Cbass94 Cbass94 is offline
Send a message via MSN to Cbass94
Re: Squeeking From Drivers Side
Have him check the bearings. If he turns to the right (putting pressure on the driver's side tire) the noise will get worse if it's the bearings. If it doesn't seem to get worse when he does that, I would say that there is probably dirt or dust between the pad and the rotor. Sometimes it gets in there and embeds itself in cheap pads. Where did he get the pads from? Are they the stock LR pads or are they some cheap aftermarket ones? If it's dirt in there, sometimes you have to take off the pad to remove it and clean them. Good luck with it, and let us konw what you find out.
Brad
