Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 05-06-2004, 07:48 PM
1979Lee's Avatar
1979Lee 1979Lee is offline
Question how do you to deativate the daytime running lamps?
Hello everyone!!!
does anyone know how to deativate the day time running lamps on a 02 sl2 sohc 1.9L saturn without unpluging the bulb's?
thanks
Old 05-14-2004, 12:57 AM
mcknt mcknt is offline
Re: how do you to deativate the daytime running lamps?
Here is a thought for what it is worth...
Have you ever noticed that when you turn the car on and have the parking brake set, the running lamps are off? It may be possible to make the switch that controls that function to stay that way. Only problem is I think the brake light on the dash will stay on as well. Might give you a starting point to look at. Good luck.
Old 05-14-2004, 11:46 AM
SabreKhan's Avatar
SabreKhan SabreKhan is offline
The middle pedal is bad
Headlights are all one fuse, I take it?
Look at the teeny picture of my car!
2004 Impreza WRX (SCCA DS 519)
2000 Saturn SL
Old 06-30-2004, 09:19 AM
mvpeters mvpeters is offline
If it's the same as a 98SC2 - Pull the DRL relay - it has 5 pins, 3 on the top row, two on the bottom. Find a short 2" piece of romex wire, bare the ends & flatten them a little to match the relay pins. Bend it to a U shape. Push one end in the center socket on the top row, push the other end in the left socket on the bottom row.
Tape the relay inside the fuse-box cover in case you want to restore the DRLs. This mod has NO effect on parking brakes or headlights.
To check that it's all OK, make sure you still have a right-side high-beam & NO DRLs.
Old 07-01-2004, 01:16 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
pull the DRL relay or DRL fuse, no need to touch the headlamp fuses (there are two)
Old 07-06-2004, 05:48 PM
Lucas1 Lucas1 is offline
you could just pull the relay. however, on a '02 i think the service wrench light will stay on if that relay is missing.
just curious, why would you want to disable them?
Old 07-29-2004, 05:53 PM
zippy_LiL_SL1 zippy_LiL_SL1 is offline
Send a message via Yahoo to zippy_LiL_SL1
A small tutorial...
Here's a tutorial on the RIGHT way to do this.
http://www.saturnfans.com/forums/sho...threadid=38952
Old 07-31-2004, 05:03 PM
good job zippy, BTW what year is that car?
