Go Back   Automotive Forums Car Chat > Honda > Integra
Old 05-06-2004, 07:42 PM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
uncirtainty
uhhh, i was lookin around in my engine compartment yesterday looking for the engine code.. i looked all over with a flashlight along the left side and all around the tranny.. couldn't find it.. also, i think the stock distributor code is TD-46U... the one on my car is TD-55U.. anyone know what engine this is from?
edit: ergh nm td-55u is the right code for my car.. but i still can't find the code for it.. think someone could have scratched it out?
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 05-07-2004, 08:33 AM
4drLS 4drLS is offline
Re: uncirtainty
look right next to ur tranny numbers it will be kinda hard to see most likely due to oil and crap so just clean it off down there and u should see it if it is a B18A1 then that is 90-93 and if it is B18B1 then that is a 94-95 or so motor that could be why ur distributor numbers are different
4 Door LS
~MODS~
-Cold air intake
-Cat Back Exhaust
-ACT 8.8 lb Flywheel
-Exedy Stage 1 Racing Clutch
-Short Shifter
-STR Cam Seal
-5 inch tach
-Rims
-Coilovers
