Go Back   Automotive Forums Car Chat > Toyota > MR2/MR-S
Old 05-06-2004, 05:01 PM
jazon720 jazon720 is offline
high speed wind noises
when i go like past 65mph and the windows are rolled all the way up, wind still can get through the top and it makes an anoying wistleing sounds. some one told me i should just change the rubber lining around the window frame on the car but i'm just wondering if there is a different way to fix it
Old 05-08-2004, 09:56 PM
Tercel GTS Tercel GTS is offline
Send a message via Yahoo to Tercel GTS
Re: high speed wind noises
sure, slow down
click to chat at StonerScript
Old 05-08-2004, 10:22 PM
froggy24 froggy24 is offline
If you have t-tops and the noise is coming from the top, then it's the t-top seal. You can replace those. If the noise is from the front or the rear of the window, then the weatherstripping on the body needs to be replaced. There is a write up on how to fix the t-top seals but it was for an MKI body style. It should be the same theory though. Visit www.highandtight.com/TTopFix.htm
Old 05-08-2004, 11:37 PM
kewl, thanks for the help but i don't have t-tops. i guess i'll just change the weather stripping.
