The trim (I think that is the term), the rubber strips on the door sides. Well, mine are falling off like so may VWs I see driving. I tried a few different adhesives to get it back on the car. After awhile it would fall off again. Does anyone have a clue the best way to fix these strips?
Re: Outside Door Rubber Strips
3M makes a very good body trim adhesive tape for this application. Go to a bodyshop supply store.
what is the name of the 3M product, and would I find it at autozone. Also does anyone know of an upgrade...such as hard plastic pieces, or something besides the rubber?
are you talking about the weather stripping?
KMillar |
No the rubber strips on the outside of the door on the level with the wheel wells. To protect the door panels from other car doors hitting the sides. They are just attached with a glue and they come off very easlyNo the rubber strips on the outside of the door on the level with the wheel wells. To protect the door panels from other car doors hitting the sides. They are just attached with a glue and they come off very easily. I tried fixing them with silicone and some other glues for plastic. But when the weather changes and the rubber shrinks and expands with the heat/cold, it comes off the car. I just need to know if there is anything better that I can use that will fix this, or body upgrade.
I have had good luck with gorilla glue which I got at home depot. I glued down the edges as they started to come loose. I applied the stuff with a small brush and clamped down the edges with bar grip clamps, keeping the doors open for a few hours to accomodate the clamps. Dont over use the glue since it expands as it cures.
The 3M tape is called body trim adhesive tape & is only available at professional body shop supply stores.
Re: Re: Outside Door Rubber Strips
I'll have to go look, the stuff I use costs about $30 a roll (1"x50') and specifically made for auto trim. 3M makes lots of types of tape, it's not the two sided carpet type tape they also make?
I'll have to look for it there, sound like the same stuff. That's about what I'm having to pay (by the foot). I don't always need such a big roll though, it takes me about a year to go through these big rolls.
I like the look leave it off
