Old 05-06-2004, 01:34 PM
blitzcivic's Avatar
blitzcivic blitzcivic is offline
bolt on or jdm
q: is it better to buy a bolt on turbo kit for a non turbo 2.0dohc or to buy a jdm turbo motor?
which is easier,and what steps should be taken?
Old 05-06-2004, 02:17 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: bolt on or jdm
im assuming this is to go into a nt talon/eclipse/laser. if you buy the turbo kit it prob includesstuff to make the wiring work. if you buy the engine then you need a turbo wiring harness, ecu, etc. check out the "for anyone interested in turboing a RS/GS" thread in the mitsubishi eclipse forum
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
