Old 05-06-2004, 12:08 PM
2crunk's Avatar
2crunk 2crunk is offline
Exclamation Huge Problem w/'95 Eclipse
I have a '95 eclipse rs, 2.0 DOHC, and a rod has started knocking!!! This motor has alot of miles on it and i was wondering, do you think it would be best or cheaper to go ahead and fix the motor thats in the car now or look for another motor to put in it. Also, if you recommend a new motor where could i go to get a good cheap one? Thanx for the help.
Old 05-06-2004, 12:26 PM
LittleGSEclipse LittleGSEclipse is offline
Send a message via AIM to LittleGSEclipse
Your best bet would be to just go and buy another one. Especially it it has really high miles. I had the same exact problem. I have the same year car. I found an engine from a 98 with only 50k and I paid 600 for it. Make sure you keep your old engine. Because if the wiring on the new engine is cut (like mine was) then none of your sensors are going to match up well some will but some wont so you will need to take your old sensors off to match up with the wiring.
If you decide to change with a new engine and are going to do the work yourself let me know I will have alot of helpful info. I just did the same shyt myself less then a month ago.
Oh and check the local salvage yards. I actually had to drive about 2 hours to pick my engine up. but well worth the money I saved.
Old 05-06-2004, 12:37 PM
2crunk's Avatar
Re: Huge Problem w/'95 Eclipse
Does a '98 have the same motor mounts as a '95? And if so, what year eclipse motors will fit in the '95?
Old 05-06-2004, 12:46 PM
Urban_Squrill's Avatar
Urban_Squrill Urban_Squrill is offline
Send a message via AIM to Urban_Squrill Send a message via MSN to Urban_Squrill
I an looking for a block(420a). But no one in a few hundered miles has a eclispe not to mention a 420a.
Old 05-06-2004, 12:52 PM
Anything from a 95-98 will fit in there with no problem. As long as its the 420A you shouldnt have any problem.
This is what you need to do to locate one
1-Go on www.Anywho.com
2-Select the category button
3-Put in your state
4-Put in auto salvage
5-Get some coffee
6-Take an hour or so and just call up everyone.
Thats What I did. It took a while but it worked.
Old 05-06-2004, 01:15 PM
2crunk's Avatar
this is my first eclipse, whats a 420a?
Old 05-06-2004, 01:35 PM
Nstyle29's Avatar
Nstyle29 Nstyle29 is offline
Send a message via AIM to Nstyle29 Send a message via MSN to Nstyle29
420a is the engine that you have in your car
Check out my 95 GS-T --> http://www.cardomain.com/id/nstyle29
Old 05-06-2004, 01:38 PM
2crunk's Avatar
Are there diiferent style engines that were made for this car, or is there just this one and the motor w/turbo?
Old 05-06-2004, 01:52 PM
Re: Re: Huge Problem w/'95 Eclipse
Basically if you have a 2g and its non turbo you have a 420a. The trubo motor is the 4g63.
Any 420a and you should be good to go.
Old 05-06-2004, 02:05 PM
2crunk's Avatar
oh, thanx for the info littlegs
Old 05-06-2004, 02:21 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Just make sure it is a eclipse 420a, not a neon!
For Sale 98 Eclipse GS, 5 spd
Old 05-06-2004, 02:26 PM
Yes correct make sure its a 420a from an eclipse.I dont know exactly whats the difference but It does need to be the 420 from an eclipse
By the way whats the difference between the eclipse 420a and the neon 420a?
2crunk's Avatar
what do you mean ashah?
Old 05-06-2004, 02:36 PM
ashah000's Avatar
The engine in the Neon and Eclipse is both a 420a, but its just a little different. The engine is backwards exhaust manifold on the firewall side.
Try to do a compression test before you buy it.
