Old 05-06-2004, 09:15 AM
coldhell9 coldhell9 is offline
Question electrical knowledge
Ok guys here's one for ya. Turn the key and nothing. Turn the headlights on and I get a clicking sound in the taillight relay under the hood. Relay has been replaced and the battery has a full charge. Any ideas? Was told I might have a bad ground? But where?
Old 05-06-2004, 09:19 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: electrical knowledge
What about the starter? If it's locked you can always hit it with a hammer to try to break it loose. I don't remember if you can get a hammer up there or not.
Old 05-06-2004, 11:34 AM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
check the resistance between the negative terminal of the battery and the frame. it should be low if its not try a different spot on the frame if you dont get a connection anywhere check your negative battery cable
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 05-06-2004, 12:00 PM
LittleGSEclipse LittleGSEclipse is offline
Send a message via AIM to LittleGSEclipse
definately check your wires. Make sure there are no ends where they are touching metal. Also check that ground.
